Pigfords OLD effort......now JULES NEW PROJECT!!!!!
Big John
#16 PostAuthor: Big John » Tue Aug 05, 2008 7:24 pm
Nice one, knew an ELR made sense. What rear shocks are they? look a bit odd to me. Otherwise looks good. :)
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
#17 PostAuthor: Pigford » Tue Aug 05, 2008 7:58 pm
Good question BJ.... :?: :?: :?: :?: :?: :?: Anyone :|
london calling
#18 PostAuthor: london calling » Tue Aug 05, 2008 9:04 pm
Fournales air shocks :?:
Jack
Big John
#19 PostAuthor: Big John » Wed Aug 06, 2008 5:05 pm
Soon to be replaced by ZRX KYB shocks Mark?
#20 PostAuthor: Rich » Wed Aug 06, 2008 5:46 pm
Looks good Piggy - better than that old nail you had :wink: I suppose you'll be replacing all those non-original bits with the proper stuff :lol:
#21 PostAuthor: Pigford » Wed Aug 06, 2008 6:51 pm
Rich, as ita all older modifications, I ain't planning to do too much, except for tidying & tweaking :lol: Just been for a 20 mile ride.... :|
C&S are shagger, a bit lumpy/rough running on low revs, but sails along OK over 3000 rpm :wink:
Poor things been a bit neglected the last few years (things like gear lever bit was loose) but overall engine seems sound enuff :twisted:
Gonna have to have the sprox cover off at the weekend to check front sprox and gear shaft is a bit wobbly :roll:
Brakes are worse than the RedZed (with only ONE front disc) :!: :!: :!:
Davy Doherty
#22 PostAuthor: Davy Doherty » Wed Aug 06, 2008 7:55 pm
Now i can see why you busted your gut to sell the 1000, Nice bike Mark good luck with her.
Life's too short!
#23 PostAuthor: Pigford » Wed Aug 06, 2008 8:00 pm
Thanx Davy.......
Gonna need some tlc.......... so I'd best get saving :wink:
london calling
#24 PostAuthor: london calling » Wed Aug 06, 2008 8:34 pm
Piggy,there's nothing wrong with your bike that money won't fix :wink: :lol:
Jack
#25 PostAuthor: Pigford » Sat Aug 09, 2008 3:55 pm
Whipped the carbs off last night.....
They were NOT RS38's..... but RS34's..... :evil:
So..... they are now sold & on the hunt for some more suitable items... :twisted:
34's will not allow the bike to make the most of the engine work... :cry:
It was taking a good 30 seconds to get the bike started.... then a while to warm up & stop spitting :!:
Took plugs out and gave 'em a clean (NGK's :?? ) but at least the threads in the head were all good.... It's always a bit of a worry when you start checking out a new bike :shock:
Might try the RS36's off me Black Zed to see how the ELR runs :|
shrekward
#26 PostAuthor: shrekward » Sat Aug 09, 2008 6:19 pm
My Zed is the same capacity now Piggy and I've got a set of Gary Baldi's fitted.
She runs blindingly now dear fellow!
Seriously "my" man thinks 39's will do the job for me and that with standard cams (I don't bloody know!) but seems strange in which case yours is struggling a bit (?)
#27 PostAuthor: Pigford » Sun Aug 10, 2008 8:20 am
Right then..... horrid wet Sunday... in the garage.. :twisted:
Chains Donald-Ducked, so off it all comes...
The swingarm is a JMC & everthing comes apart easily :P
Rear wheel is apparently a CMA (Cast Magnesium Alloy :wink: ) and nice & light, no cracks evident :wink:
The front sprocket on these Square cam engines is off-set:
........... so can be used on older Zeds for adapting WIDER tyres :twisted:
The chain is a 630 so gonna pop into TALON in Yeovil tomorrow (only a 200yds from one of our Concrete Depots) and find out about a 530/525 conversion :shock:
The rear sprocket carrier is a cool arrangement with bolts acting as studs, which fit into the wheel hub, which has rubber inserts that act as shock-absorbers :!: Neat :lol:
That'll be a good £100 tomorrow then :roll:
shrekward
#28 PostAuthor: shrekward » Sun Aug 10, 2008 8:40 am
Piggleonion, in the first picture the biscuit box states "more a chocolte than a biscuit", which got me thinking about a similar quote I had heard a little while back.......................................... "Pigford, more biscuit than man"
#29 PostAuthor: paul doran » Sun Aug 10, 2008 8:39 pm
I got a set of those CMA's a couple of year's agp
they are so similar to Dymag's and really suiy the Lawson's
#30 PostAuthor: Pigford » Sun Aug 10, 2008 8:44 pm
Cheers for the confirmation, Papa Paully :wink:
