WINTER PROJECT TO RESTORE A NEGLECTED UK SPEC Z1B
- DogsbolloxofZ1B
- DogsbolloxofZ1B
- RALPHARAMA
I am curious that you have chosen to completely assmble the engine unit before putting it in the frame. I was going to build the rolling chassis, then fit the engine with minimum assembly into the frame, so that it is at it's lightest and smallest giving me the least likelihood of chipping the powder coating. This is the first time I have assembled like this but traditionally one fits to a rolling chassis. As everything on the zed engine can be fitted in the frame, save the gearbox split, I thought this was the best bet. I still haven't got any barrels either which helped the decision for the top end.
I should be interested in opinions on this.
Looking fab! Mine will never be that good!
Ralph Ferrand
- DogsbolloxofZ1B
Recently did mine by dropping frame over the assembled motor, much easier and less risk of damage (I did cover frame rails with tape as a precaution). Assembling the motor on the bench is so much easier than fighting with the barrels and head when in the frame.
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
1975 Z1B, 2013 Z800
- DogsbolloxofZ1B
- paul doran
