WINTER PROJECT TO RESTORE A NEGLECTED UK SPEC Z1B
ROZZER
#61 PostAuthor: ROZZER » Wed Jan 23, 2008 9:47 am
Paint flaked off due to presence of ferrous oxide (posh rust).
I for one am confident that Dogsbollox will rectify this serious fault and will self flagilate as pennance for his sin (if it was me I'd blame Bedlow cos he's in Spain).
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
#62 PostAuthor: Rich » Wed Jan 23, 2008 5:42 pm
Ah once you have the rust gremlins there they will spread to the rest of the bike and slowly eat away at it until one day it disappears up it's own exhaust pipe. You may as well scrap it now - you have been warned!
MaineKZ
#63 PostAuthor: MaineKZ » Wed Jan 23, 2008 8:08 pm
Quite right Rich - I had a Lancia Fulvia that did exactly that in a matter of minutes. I was lucky to get out alive.
Dogs - Straight to the crusher with it - and no passing 'Go' nievah.
DogsbolloxofZ1B
#64 PostAuthor: DogsbolloxofZ1B » Sat Jan 26, 2008 5:39 pm
Clutch going back in:
Pushrod Steel ball in situ:
Plunger installed:
Cover & springs prepped:
All torqued down ready to go:
Kick Starter cover etc installed:
DogsbolloxofZ1B
#65 PostAuthor: DogsbolloxofZ1B » Sat Jan 26, 2008 5:42 pm
With the much appreciated help of Steve Thomas this afternoon we lowered the whole lot onto a small engine lift in readiness for the final assembly.
RALPHARAMA
#66 PostAuthor: RALPHARAMA » Sun Jan 27, 2008 1:03 pm
I am curious that you have chosen to completely assmble the engine unit before putting it in the frame. I was going to build the rolling chassis, then fit the engine with minimum assembly into the frame, so that it is at it's lightest and smallest giving me the least likelihood of chipping the powder coating. This is the first time I have assembled like this but traditionally one fits to a rolling chassis. As everything on the zed engine can be fitted in the frame, save the gearbox split, I thought this was the best bet. I still haven't got any barrels either which helped the decision for the top end.
I should be interested in opinions on this.
Looking fab! Mine will never be that good!
Ralph Ferrand
DogsbolloxofZ1B
#67 PostAuthor: DogsbolloxofZ1B » Sun Jan 27, 2008 5:23 pm
Ralph,
I used to build the rolling chassis first but having seen how Marsden does his I thought I'd give it a go and it is really much easier so long as you've got a few mates to help do some lifting. Oh, you do need two people to carefully position the frame over the engine.
#68 PostAuthor: chrisu » Sun Jan 27, 2008 5:33 pm
the last one I did was using the 'frame over engine' method - I thought it was much easier.
#69 PostAuthor: Rich » Sun Jan 27, 2008 7:32 pm
Always put the frame over the engine on the Harris - it's a total bitch otherwise, just tape newspaper around the tubes to stop the scratches.
ROZZER
#70 PostAuthor: ROZZER » Sun Jan 27, 2008 8:22 pm
Recently did mine by dropping frame over the assembled motor, much easier and less risk of damage (I did cover frame rails with tape as a precaution). Assembling the motor on the bench is so much easier than fighting with the barrels and head when in the frame.
1975 Z1B, 2013 Z800
Ed Z1-R
#71 PostAuthor: Ed Z1-R » Sun Jan 27, 2008 9:22 pm
When i rebuilt the Z1-R it was frame over engine.
Prior to that the headstock bearings and centre stand were fitted.
Just asked the neighbour to help get the bike elevated on the C.stand and slip axle stands under the cradle so i could fit front end etc :lon
DogsbolloxofZ1B
#72 PostAuthor: DogsbolloxofZ1B » Sun Jan 27, 2008 9:45 pm
Another couple of hours tonight... Got the steering stem installed, front forks, all the bright shiny bits mounted. Mudguard & front wheel by Tuesday.
bedlow1
#73 PostAuthor: bedlow1 » Mon Jan 28, 2008 10:03 am
DOGS BOLLOX- POST CARD FROM SPAIN
WISH YOU WERE HERE.
TEMP 21C - TOOK BIKE OUT FOR A SPIN AND ENDED UP AT A NICE BEACH, COOL BEER, BIT OF SUNBATHING AND WATCHING THE GIRLS GO BY!
NO SLACKING NOW,GET ON WITH THE Z1B PROJECT BIKE
SEE YOU TUESDAY
BEDLOW
#74 PostAuthor: paul doran » Mon Jan 28, 2008 7:22 pm
nice one Graham
MaineKZ
#75 PostAuthor: MaineKZ » Mon Jan 28, 2008 8:14 pm
Dogz - is Gra really expecting a share of the profits on this one?
Ok, he makes a nice cup'o splosh.... but you gotta draw the line somewhere :roll:
