Head washers 92022-215
Richard Q
#1 PostAuthor: Richard Q » Sat Nov 29, 2014 10:26 pm
My parts manual says these washers, under the cylinder head nuts are, "Plain Washers." The ones on my bike, are 1.5mm thick copper washers.
I have found some for sale at £33.00 a set for a Z1, or £4.00 for just 1.2mm thick copper washers. Is there something special about these washers, or can I use any copper ones?
Richard
1976 KZ900
Z1parR
#2 PostAuthor: Z1parR » Sat Nov 29, 2014 10:29 pm
Nothing special about them , just an odd size .
You only need a copper washer under the outer 4 nuts .
0172 . Geoff Parr
Richard Q
#3 PostAuthor: Richard Q » Sat Nov 29, 2014 10:33 pm
Z1parR wrote:Nothing special about them , just an odd size .
Thanks for that, the parts manual says they are 12 of them. Do the inner ones have steel washers or no washers?
Richard
1976 KZ900
Z1parR
#4 PostAuthor: Z1parR » Sat Nov 29, 2014 10:35 pm
Just steel washers on the inner eight .
0172 . Geoff Parr
Richard Q
#5 PostAuthor: Richard Q » Sat Nov 29, 2014 10:36 pm
Ta :D
1976 KZ900
#6 PostAuthor: z1bman » Sat Nov 29, 2014 10:53 pm
there was a discussion about this previously you can get the copper washers from e bay for about £ 8 for a full set of 12 the inner 8 are just steal washers but you can use copper if you wish
malmojoe
#7 PostAuthor: malmojoe » Sat Nov 29, 2014 11:06 pm
saved this in my ebay after someone else posted it, I haven't checked the size or bought them.
http://www.ebay.co.uk/itm/270848931025?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Richard Q
#8 PostAuthor: Richard Q » Sat Nov 29, 2014 11:15 pm
malmojoe wrote:saved this in my ebay after someone else posted it, I haven't checked the size or bought them.
You get a pack of 20 here for £4.00. 20 off- 22.3mm O/D X 11mm I/D X 1.2mm Thk. 1.2mm instead of 1.5mm, but I don't think that would cause much of a problem.
http://www.ebay.co.uk/itm/131337647590? ... EBIDX%3AIT
1976 KZ900
#9 PostAuthor: Ginger Bear » Sun Nov 30, 2014 9:10 am
Great link..... I've just bought the last pack. :nikd :wink:
# 104
ted1r
post
#10 PostAuthor: ted1r » Sun Nov 30, 2014 7:17 pm
They are available from merchandizing £12.00 a pack of copper ones. only a few packs left though and will not be replaced.
Ted
"Work this is why I did it"
"I've had more minutes than I have left"
Z1R D1
Granada
vantastic Transit........
KLE650
