Clutch
Wayne1960
Clutch
#1 PostAuthor: Wayne1960 » Sat Sep 13, 2014 8:19 pm
Guys finally got bike running and sounding good. Thanks the Dave (buzzard for the work he did on my head and the rebore.
Clutch question. Bike sound better when I pull the clutch in! When I let it out its sounds noisier. So do I adjust or is it something else?
Bike now finished what a joy!
000zeds
#2 PostAuthor: 000zeds » Sat Sep 13, 2014 8:44 pm
Could be a couple of things, Idle speed a bit low or carb balance may need fine tuning and the worst thing it could be is the needle roller clutch bearing worn as that is an engine strip to replace.
Zeds-R-Us
Wayne1960
#3 PostAuthor: Wayne1960 » Sat Sep 13, 2014 9:54 pm
Ok great well I've been fine tuning carbs and adjusting the needles set at 1.5 turns out and checking idle speed while adjusting and that did make a difference.
What other adjustments should I make?
If I let it tick over for say 5mins the turn throttle quickly it cuts out!
Starts again ok and responds ok but get a slight popping so could be getting air leak somewhere I guess.
#4 PostAuthor: PAULJAC47 » Sun Sep 14, 2014 9:08 am
If the clutch is rattling,and goes away when you pull clutch in as said by two zeds it can sometimes be made less by carefully balancings carbs,that said the tickover should not be more than 1200 rpm,if rattle persists usually broken springs in the back of the clutch.Popping can be air leaks check exhaust headers etc..
#5 PostAuthor: Pigford » Sun Sep 14, 2014 5:54 pm
THEY ALL DO THAT SIR - Don't worry, it's common on lots of a/c 70's Jap bikes :!:
Basket springs maybe shot - take clutch cover off & plates out and see how much slack they have - may even have a broken spring or two.... not end of the world, but a full engine strip to remove clutch basket on kickstart engine.
Wayne1960
#6 PostAuthor: Wayne1960 » Sun Sep 14, 2014 6:12 pm
Just had it running and adjusting carbs and tickover have made a big differance. its the stalling if i quickly tun the throttle thats getting me? is there an easy way to check for air leakage?
if i put my hand over the end of the exhaust they all feel abput the same. 1,2 & 3 pipes have yelloewed bit 4 no change.
thing is i cant ride it yet cos i never took my test !!!!!!!
#7 PostAuthor: Pigford » Sun Sep 14, 2014 6:29 pm
Stalling on initial throttle opening is a fairly common problem with Zeds - the old carbs seemed a bit lean when briskly opened, just inferior design back in the day although they don't all do it.
Try and wind the sir screw in a bit to richen it up a tad - or just coax it gently when pulling away :!:
#8 PostAuthor: z1bman » Sun Sep 14, 2014 6:37 pm
get a colour tune if you don't want to ruin your new exhausts
Wayne1960
#9 PostAuthor: Wayne1960 » Sun Sep 14, 2014 7:09 pm
im guessing being that golden yellow and not shiny chrome ive already ruined them a little.
#10 PostAuthor: z1bman » Sun Sep 14, 2014 7:19 pm
a good chrome polish will bring them back but your stuffed if they go blue
#11 PostAuthor: z1bman » Sun Sep 14, 2014 7:22 pm
Wayne1960
#12 PostAuthor: Wayne1960 » Tue Sep 16, 2014 7:15 am
Z1b man how does the colour tuning work?
#13 PostAuthor: z1bman » Tue Sep 16, 2014 7:52 am
it allows you to see what's happening inside the combustion chamber. it is basically a spark plug with a glass top & good basic tool for setting the fuel mixture
https://www.youtube.com/watch?v=V9bzs2TUOcQ
#14 PostAuthor: z1bman » Tue Sep 16, 2014 8:02 am
#15 PostAuthor: z1bman » Tue Sep 16, 2014 8:22 am
