dynatek
Ray
I have just open a brand new pack of DW 600 silicon leads and the resistance reading between the 2 ends before being cut is 15.8 K ohms.
I assume you have followed the instructions and turned the inner silicon core back onto the outer rubber sheath and then applied the crimp collar before securing with a crimping tool or pliers.
Regards
Steve
Regards
Steve
wilsonsjw11 wrote:Ray
Regards
Steve
I think my meter is low on battery so I will get a new pp9 to check
ta
its a DC1-1
If fitted the dyna leads but Ive used my own plug caps as I dont like the look of the dyna ones (sad) , I got my meter to read for a few secs so they are conducting ok, the points sys fits up easy enough , but the coils are way bigger so I need to get some longer mount bolts. Ive always felt the replica back plate set and general spark was the weak point of the running
thanks
Ray
thanks
Ray
yep , your right ....Ive already gut off the dyna leads caps.. horrid screw on tops to the plugs as well
so I will try a set as they are now to see if it gets a better spark - it was pretty piss poor sparks when compared to medern systems. I will update the thread , it would have been tonight but Im still at work
