dynatek
wilsonsjw11
Ray
I have just open a brand new pack of DW 600 silicon leads and the resistance reading between the 2 ends before being cut is 15.8 K ohms.
I assume you have followed the instructions and turned the inner silicon core back onto the outer rubber sheath and then applied the crimp collar before securing with a crimping tool or pliers.
Regards
Steve
Regards
Steve
wilsonsjw11 wrote:Ray
Regards
Steve
I think my meter is low on battery so I will get a new pp9 to check
ta
wilsonsjw11
its a DC1-1
If fitted the dyna leads but Ive used my own plug caps as I dont like the look of the dyna ones (sad) , I got my meter to read for a few secs so they are conducting ok, the points sys fits up easy enough , but the coils are way bigger so I need to get some longer mount bolts. Ive always felt the replica back plate set and general spark was the weak point of the running
thanks
Ray
thanks
Ray
wilsonsjw11
wilsonsjw11
yep , your right ....Ive already gut off the dyna leads caps.. horrid screw on tops to the plugs as well
so I will try a set as they are now to see if it gets a better spark - it was pretty piss poor sparks when compared to medern systems. I will update the thread , it would have been tonight but Im still at work
