If there is anything else out there that fits please let me know, I can build up extra knowledge on the ST database....
Z 1000 ST Front mudguard
- Vendetta761
Front mudguard of an ST required, believe a Mk2 is the same but happy to be corrected if that is not the case [everything else on the ST is .0003mm different so no reason its not this time].
Z1000 ST x 3 , Moto Guzzi G5 special ,V11 special.
- Vendetta761
Front Mudguard Z 1000 ST
Thanks chief, ST mudguard only it is, still looking for one , cash and biscuits waiting....
- Vendetta761
mmm, rarer than I thought.
In that case, I can modify up another mudguard with a similar radius, seem to be a lot of specials out there with trick front mudguards but a lot of them are plastic, I was under the impression the Z solid number acted as a little brace so wanted sturdy metal.
Anyone any ideas for something I can butcher, I mean modify?
- Vendetta761
Thanks Freddy and Yeloow, at the moment i have one bike that will be a dry run bike only if i do not get some kind of mudguard on it, i know the original is solid and strong and acts like a bit of a brace ( I too have been hunting for a micron or telefix or similar but no luck so far)
If you have a spare one Yellow then biscuits and beer tokens can be made available, all in a good cause you know
If I cannot sort a mudguard then for the while it will be a dry run bike which may not be a prob, could look pretty mean but I think some kind of brace must be required.
Thanks for the replies, much appreciated
- Vendetta761
