front wheel alighnment.
hillbilly
#1 PostAuthor: hillbilly » Sat Aug 15, 2009 5:39 pm
anyone got detailed pics with measurements,of the front wheel spindle spacers on a z1 900.thought they might be the same,but my front wheel is out of line.onlyfour mill but the twin brake calipers wont go in together. :cry:
KeithZ1R
#2 PostAuthor: KeithZ1R » Sat Aug 15, 2009 6:01 pm
are the bearing out or in to the shoulders suffered the same problem with a rear wheel drove me insane till i spotted it obvious I know but somtimes wood for trees :!:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
hillbilly
#3 PostAuthor: hillbilly » Sat Aug 15, 2009 6:30 pm
bearings are ok,ive even tried a h1500 front spindle,gona afta get the grinder out me thinks. :?: the first one was an a1/2 front axle,but found out that they are wider across the bottom.
Taffus
#4 PostAuthor: Taffus » Sat Aug 15, 2009 6:50 pm
check the speedo drive is located properly
(\__/)
(")_(")Image
hillbilly
#5 PostAuthor: hillbilly » Sat Aug 15, 2009 6:59 pm
now this might be right or it might just be me clutching at straws,but i have the top triple tree off a z1,the bottom triple tree might be an a1/2,are the z1000 yokes wider than a z1. :?:
bigmac103
#6 PostAuthor: bigmac103 » Sat Aug 15, 2009 11:31 pm
same thing happened to me a while ago and Taffus has a very good point! It certainly was my problem.
Lost in the desert somewhere
london calling
#7 PostAuthor: london calling » Sun Aug 16, 2009 7:47 am
I've got a Z900 A4 bottom yoke if you need it :?:
FOC just cover the postage :wink:
Jack
hillbilly
#8 PostAuthor: hillbilly » Sun Aug 16, 2009 9:47 am
thanks jack,i think i will have a measure up first to see if it is my problem,will be in touch. :wink:
hillbilly
#9 PostAuthor: hillbilly » Wed Aug 19, 2009 1:10 pm
got it today jack,thanks again,ps,send me your address then i can send you the postage.its only fair. :wink:
hillbilly
#10 PostAuthor: hillbilly » Fri Aug 21, 2009 6:32 pm
maybe not to clear,but the ruler was touching both sides of the yolk on one side,and the other end was deffinately out a fair bit.problem solved,cheers jack. :lol:
