air intakes
- big green bus
air intakes
i have fitted a usa style cylinder head to my gpz1100 turbo. it has the reed valve air intake on i was going to leave it on with a air scoop facing forward. my thinking was that a bit of cold air around the exhaust valve and pipe could not hurt. the bike is now ready for donno but sounds like a diesel taxi with these ports open. has anybody any ideas how i can keep them open without the horrible sound? or will the cold air give me more bother than it is worth
- Jeff Saunders
most of the drag-racers eliminate those darned things...
...one fix is to reverse the reed-valves and bolt the covers back down - effectively blocking the ports.
- big green bus
- Jeff Saunders
you can't just replace the cam cover - if you do, it'll leave the ports open and they be shooting flame out under the tank....
Perhaps one of the other more enlightened members can give you some more solid info!
