air intakes
big green bus
air intakes
#1 PostAuthor: big green bus » Wed Jan 31, 2007 7:07 pm
i have fitted a usa style cylinder head to my gpz1100 turbo. it has the reed valve air intake on i was going to leave it on with a air scoop facing forward. my thinking was that a bit of cold air around the exhaust valve and pipe could not hurt. the bike is now ready for donno but sounds like a diesel taxi with these ports open. has anybody any ideas how i can keep them open without the horrible sound? or will the cold air give me more bother than it is worth
#2 PostAuthor: Pigford » Wed Jan 31, 2007 7:34 pm
I'm not too sure, but i thought these reed valve things were a USA mod to help reduce emissions and are usually blanked off, not left open? :? Perhaps one of the other more enlightened members can give you some more solid info! :roll:
Jeff Saunders
#3 PostAuthor: Jeff Saunders » Wed Jan 31, 2007 11:43 pm
most of the drag-racers eliminate those darned things...
...one fix is to reverse the reed-valves and bolt the covers back down - effectively blocking the ports.
Pasc
#4 PostAuthor: Pasc » Thu Feb 01, 2007 11:01 am
Leaving them open without blanking plates or the original emissions kit is basically similar to having exhaust leaks around the manifold clamps/ exhaust ports, hence the row its making. You can either replace the cam cover for a uk spec one or if I remember Debben sell some APE blanking plates.
big green bus
#5 PostAuthor: big green bus » Thu Feb 01, 2007 8:21 pm
thanx guys i will just change the cam box after the show
Jeff Saunders
#6 PostAuthor: Jeff Saunders » Thu Feb 01, 2007 9:23 pm
you can't just replace the cam cover - if you do, it'll leave the ports open and they be shooting flame out under the tank....
Pasc
#7 PostAuthor: Pasc » Fri Feb 02, 2007 9:46 am
But Jeff, he can replace the cam cover for a Uk version which won't have any of the emisssions rubbish and will blank the holes when fitted. Had to do this with a Cali import Gpz1100b2 I had.
