took the bike out for 7 miles,[first run this year] ran very well. has new denso plugs. i have put the combined reg/rec from zpower on. got back, the ht leads were really hot and there was smoke coing from under the tank. Hello Guest User,
hot,hot leads
- mick znone
hot,hot leads
another problem guys
ive done something wrong.
took the bike out for 7 miles,[first run this year] ran very well. has new denso plugs. i have put the combined reg/rec from zpower on. got back, the ht leads were really hot and there was smoke coing from under the tank. I DONT CARE, IN OR OUT BUT IM ENJOYING THE DEBATE......................ARMSTRONG MT500. a pushbike, waves.....addict, no offence
- mick znone
- mick znone
ash wrote:Mick are the coils getting hot as well as the leads,
not sure on that one. unhealthy amount of smoke coming from under the tank though. ive replaced the old set up for now. the bike then ticked over ok.
I suppose if everything has been changed to accommodate the new set up then everything shud be ok, iv found in the past mixing electrical old with new can cause some probs, even down to the old loom, iv done loads of old zeds up and the amount of melted electrics due to just adding half whats needed cause so much shit, i just love these old zeds, what therapeutic joy they bring,
Good luck anyways,
Good luck anyways,
The smoke coming from under tank, will probably be the coils melting and ozing some goo. This is usually the symtom of over-voltage to the coils.
After you fitted the combined reg/rec, did you check to see if the regulator part is working? Otherwise, you have may have wired the unit incorrectly.
This checking is done by simply checking the voltage across the battery terminals with the engine running at about 3-4000 rpm. Should not be more than 14.5Volts. .... RegardZ.
Re: hot,hot leads
mick z1a wrote:another problem guystook the bike out for 7 miles,[first run this year] ran very well. has new denso plugs. i have put the combined reg/rec from zpower on. got back, the ht leads were really hot and there was smoke coing from under the tank.
I know this might sound silly but is it possible that maybe some oil residue got on the motor or header pipes, ie from rocker cover or leaky tacho cable seal, it 'd smoke like hell as it was being burned off, just a suggestion.
- mick znone
well guys, i dont have a volage checker, mainly because i dont know anything about electrics. i know this sounds negative, buts its true, think i need to learn a bit.
i did think the smoke could have been a bit of residue oil/grease, but the leads were hot and very limp, is that normal?
Heat from the motor will make leads HOT & limp......
If its still running OK sit and watch it (with an extinguisher handy) & see if it is just excess oil residue from the rebuild!
I have never heard of HT leads burning due to electric fault
- mick znone
- mick znone
took it out today 30 miles, no problem, [except the rain] it ran fine with the original set up. i do however want to put the new gear on sometime.
whilst out i bought a multi tester, tomorrow i will do the across the battery test ive heard mentioned.
- mick znone
well, i have to say, with the combined re/reg unit on the way id connected it ......IE block connection to block connector, black earth behind kick start, one white wire with double female, receiving wire with fuse from battery and one wire that i thought was coming from the generator..... there was an unhealthy looking amount of smoke coming from under the tank and the ht leads were hot soft and limp as f;ck.
confidence lost
confidence lost
