advice on wheels
advice on wheels
Hi, new to the forum and already asking for advice! I've got a z1000 B3 Ltd and I'm looking at changing to spoked wheels. Can anyone tell me if the wheels from a z1000 A2 would be interchangable for disks/spacers/cush drive etc? Anyone done a similar conversion and got any tips. Cheers mikeyboy
new
welcome mikeyboy lots of good advice here
would be nice if you
intro your self in the new section and give use some nice pics of your ride
hope you enjoy the banter here
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
Z1OC # 886
- mick znone
Re: new
compo z1r wrote:welcome mikeyboy lots of good advice here![]()
hope you enjoy the banter here![]()
seconded, welcome Mikey boy, introduce your self first.
change for z1000a2 wheels
Mikeboy,
Be aware that the Ltd runs with a different caliper to the A2, i have had an experience where is mistakenly used a Ltd rhs wheel spacer and found that on my A2 i could not tighten the wheel satisfactorily in place----it was obvious that it was not right and it was down to the spacer being about 6mm thinner--i think that the one i used first was the Ltd spacer.
It was easily sorted --i used the A2 spacer an dit was back to normal
There you go
Reecy
There you go
Reecy
