Vaccum tap
mikey
Vaccum tap
#1 PostAuthor: mikey » Sun Apr 05, 2009 5:52 am
On a z1000A2 vaccum tap when you put it on prime should fuel flow from both outlets as 1 outlet feeds 1+2 and other feeds 3+4 could this be the cause of my spluttering which now happens through out the rev range and not just at high revs as in my previous post.
tlc
International Rep
#2 PostAuthor: tlc » Sun Apr 05, 2009 6:08 am
Yes Mikey.
Prime just bypasses the vaccum aspect of the tap.
Could you have a blockage in the tap ?
Don`t forget that after a respray there will be loads of poop in the tank no matter how much you clean it beforehand :??
Asphalt Cowboy
mikey
#3 PostAuthor: mikey » Sun Apr 05, 2009 6:17 am
Just had the vaccum bit off the tap chris blew it through seems there is water?? in the tap which i guess is in the carbs as well :cry:
tlc
International Rep
#4 PostAuthor: tlc » Sun Apr 05, 2009 6:21 am
`S alright Mikey.
Just drain the carb bowls down and away you go :D
Asphalt Cowboy
mikey
#5 PostAuthor: mikey » Sun Apr 05, 2009 6:24 am
OK bud thanks ill try that see the Z1OC help machine strikes again :lol: :lol:
