So it's Time to Tidy Things up....
The road grime has got to the carbs, but you really don't want to strip them all down, and have the aqua blasted.... So what to do....
No Problem
Just build yourself a Soda Blaster....
http://www.aircooledtech.com/tools-on-t ... a_blaster/
No Problem
- Davy Doherty
- mick znone
Steve Cooke
Bazza.
http://cgi.ebay.co.uk/30lb-Portable-Air ... 240%3A1318
I got one of these and it works a treat, but you do need a powerful compressor.
I guess you could fill it with the Baking Soda ? When I use sand I get the Kiln Dried paving sand at about £5 for 20KG.
Asphalt Cowboy
very interesting... I have a near endless supply of that sand... shame your so far away.... when you say a powerfull compressor, and they say 3hp I don't suppose my 25ltr clarke jobbie would be up to it... what about in short bursts... I have a frame to do ?
Baza
Baza
Baza
Carefull with sand lads illegal in blasting trade i am told,silicosis risk!!!!!!! if using make sure you use good mask!!!!!! i have one of these cheap ebay units trying out at momeny i have doubled my compressors up to give about 120 psi you are limited by your receiver tank size to how long you can blast though......i have made a blast cabinet up from a council re-cycle box with a couple of holes for your hands to go in and a simple wood frame with a perspex window on top works fine...
Steve Cooke
The underbody gun will spray sand I also used a dry sand (block paving) but I put it through a sieve first to get rid of the bigger bits of shell and the like, as I haven't got a cabinet I just stick on goggles and a mask and blast it out the back, it's a bit wasteful on the sand and you get covered in it, but it'll take just about anything off leaving clean bare metal.
Being a tight arse :-
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0310300571
Hope that works
needs less power and it ain't as if i got a whole car to do, I will let you know how it goes.
Baza
Hope that works
Baza
Baza
