Front stop switch ?
sparky650
Front stop switch ?
#1 PostAuthor: sparky650 » Wed Mar 04, 2009 5:47 pm
Ive got a 1980 z 650 , after sorting out nearly the whole electrical sytem ive now notice that there is no brake light switch for the handlebars from the brake lever ? Not even a trace of where any switch should go ? Did this model come without a front actuated switch ? Im quite sure its the standard lever and resevoir set up.
Cheers.
sp.milne
z650
#2 PostAuthor: sp.milne » Wed Mar 04, 2009 8:07 pm
http://cgi.ebay.co.uk/KAWASAKI-Z650-Z90 ... 240%3A1318
ifs its anything like the big zeds you have a in line hydraulic switch under the headlight between the forks
floydsz1
#3 PostAuthor: floydsz1 » Wed Mar 04, 2009 8:57 pm
you can use it withought a brake light switch as long as the back one works. Cant remember what year the law changed but you only need one brake lever to work the brake light (does'nt matter if its the front lever or the rear foot pedal). my z1a passed lat week with just the front working, still waiting for a rear switch.
tlc
International Rep
#4 PostAuthor: tlc » Wed Mar 04, 2009 11:40 pm
I`ve got a 3 way junction with switch you can have for nowt Sparky
Asphalt Cowboy
sparky650
Re: z650
#5 PostAuthor: sparky650 » Thu Mar 05, 2009 6:50 am
sp.milne wrote:http://cgi.ebay.co.uk/KAWASAKI-Z650-Z900-Z1000-KZ650-KZ900-KZ1000-SPLITTER_W0QQitemZ160319403486QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item160319403486&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A10|39%3A1|240%3A1318
Ive seen the switch your talking about come to think of it but its not connected :roll: so how does that work :?: or should i say where does it connect to :?: Cheers tailiftchris, ill see if the one ive got works first and let you know if i need one ...my first question on here and you have the answers...superb :D
wilsonsjw11
#6 PostAuthor: wilsonsjw11 » Thu Mar 05, 2009 7:42 am
Sparky
The switch works on hydraulic pressure within the brake system,the wiring for it breaks out of the main loom within the headlight shell,should be a pair of wires together just ready with push on connectors(female bullets).
Regards
Steve
sparky650
#7 PostAuthor: sparky650 » Thu Mar 05, 2009 2:52 pm
wilsonsjw11 wrote:Sparky
Regards
Steve
Cheers steve ill have a look and see if i can get it wired up and working .....more wiring :roll: arrrrrgh :wink:
#8 PostAuthor: PAULJAC47 » Thu Mar 05, 2009 5:17 pm
Does the 650 have an outage switch? if so this could be problem as brake lights and outage indicator go through this unit it is switched by front or back brake switch i modified my mates a4 with a standard 12v relay, genuine outage switches seem as rare as hens teeth and are not cheap if you can find one that actually works,,,,Cheers Paul J..
sparky650
#9 PostAuthor: sparky650 » Thu Mar 05, 2009 6:58 pm
Thanks to all your helps folks :) ..the connections were there but they were loose and corroded so i cleaned them up made a tighter connection and now the brake light switch works !!!!! Fantastic :D
