Got a stiff one
Got a stiff one
The clutch on my A2 that is, always been like it, new cable oiled, adjusted as per the manual, release mechanism greased and its still stiff, you need body builders arms to pull it in
Have you checked your push rod Mikey? It could be bent or seized.
Simple to do, take of sprocket cover/casing. It should then slide out freely, if it doesn't, then that could be your problem. I believe they can get bent from chains breaking! There should be a ball bearing at the far end of the push rod, watch it dosen't come out if you have the bike on the side stand!
- mick znone
phil churchett
Ginger Bear wrote:Have you checked your push rod Mikey? It could be bent or seized.
Mikey, poor routing of the cable won't help either.
A quick word to correct part of Ginger's comment.
The ball, which activates the clutch, cannot fall out from the LHS of the machine. It is a common misconception. It can only be removed by removal of the mushroom and falls out the RHS. The diameter of the ball restricts it from rolling out the other direction. RegardZ.
Garn 1 wrote:A quick word to correct part of Ginger's comment.
Thays what i thought but didnt want to say any thing in case i was wrong and made meself look a tit, anyway checked the pushrod today rolled it on a bit of plate glass as gb suggested to me om the phone today and its flatter than a flat thing, but it did have some ridges in it so i know someone whos a polisher he aint bad
I thought you would have made a comment re "routing" and a"stiff one"
(\__/)
(")_(")
(")_(")
