Pigfords OLD effort......now JULES NEW PROJECT!!!!!
#151 PostAuthor: Pigford » Mon Dec 29, 2008 4:16 pm
Ok.............. Mrs P out again today (another shopping trip with one of her friends :twisted: )..... so its in the kitchen again... :wink:
Got me nicely rebored & painted barrels at the ready... along with the WISECO 75mm piston kit & some feeler gauges
The Wiseco's come with info in "gapping" the rings.... its:
bore size x 0.0045" for the top ring & 0.0055" for the middle :shock:
Thats 0.034mm & 0.041mm in new money :lol:
So the procedure is to fit each ring in turn into its respective bore & measure the end gap......
To ensure the ring is dead square in the bore, use the piston to push it down about 20mm...
Then you can measure the 'end gap'.... like so........
If the gap is too tight.... you will need to file the end of one side of the ring. It must be kept square to the other one & file inwards & be sure to remove any burrs :!:
Best to fit rings to correct pistons as you go - making sure they are all clearly marked & matched to the relevant bores... :??
Once this process has been done with them all you can fit 1 x circlip to each piston to hold gudgeon (wrist) pin. This is easier than trying to fit ALL of them when the pistons are fitted to the conrods :shock: Take you time & work out where each piston is going & what side is easiest to access when its time to fit the pistons & 2nd circlip.... :|
Its usually best to fit the outer most circlips last :wink:
DON'T FORGET TO MAKE SURE PISTON ARROWS (ON TOP SURFACE) ARE POINTING FORWARDS :evil:
Whilst fitting pistons, cover all crankcase openings.... bung rags on case openings beneath pistons & cam chain tunnel... :P I used some old socks (loads of new ones for Xmas :roll:
Time for more TEA & BISCUITS now :lol:
#152 PostAuthor: Rich » Tue Dec 30, 2008 9:33 am
Why don't you get Mrs P to invest in a new duvet cover so you can have the old one :?:
Then you could use it to cover the whole engine and stop all that dust from going everywhere :shock:
Don't forget to space the piston rings :wink:
#153 PostAuthor: paul doran » Thu Jan 01, 2009 9:23 pm
jeez Piglet you ain't half afraid of the better half :lol: :lol:
#154 PostAuthor: Pigford » Thu Jan 08, 2009 4:07 pm
Thank f**k :lol:
For you Technophobes...... just click the picture :wink:
There you go...... had Tuesday & today off work (coz its a bit quiet :?? ) so got stuck in & managed to run her up :P
Exhaust & stuff is just cobbled together for the moment... but ran her for a couple of minutes... :wink:
KWACKERZ1
#155 PostAuthor: KWACKERZ1 » Thu Jan 08, 2009 4:14 pm
cool post that
bike looks and sounds ace!!
baldy brent
#156 PostAuthor: baldy brent » Thu Jan 08, 2009 4:35 pm
:D :D :D WICKED !!!!!!!!!!
RALPHARAMA
#157 PostAuthor: RALPHARAMA » Thu Jan 08, 2009 4:50 pm
Sound great :D
Ralph Ferrand
PJ
#158 PostAuthor: PJ » Thu Jan 08, 2009 5:11 pm
Well done Mark I bet you are well chuffed, running at last :D :D :D
tlc
International Rep
#159 PostAuthor: tlc » Thu Jan 08, 2009 5:35 pm
Well done Mark.
Just a bit of fine tuning and you`ll be right for the Ace :D
Asphalt Cowboy
#160 PostAuthor: Rich » Thu Jan 08, 2009 5:38 pm
Remind me not to ride behind you!
#161 PostAuthor: Pigford » Thu Jan 08, 2009 5:55 pm
Thanx lads... :P :P :P :P
Always a bit nerve wracking - first time :wink:
Just gonna get it running OK this summer & enjoy :twisted:
Come end of year..... plan to do cosmetics.... Wheels, Frame, Forks...etc :!:
May even get the paint work done. :shock:
Just need to sort out those front brakes.... and when the weather turns... :lol:
Big John
#162 PostAuthor: Big John » Thu Jan 08, 2009 8:27 pm
Looking and sounding good, nice one.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
Davy Doherty
#163 PostAuthor: Davy Doherty » Thu Jan 08, 2009 9:15 pm
Good for you Mark well done, and thanks for posting it..
Life's too short!
#164 PostAuthor: paul doran » Thu Jan 08, 2009 10:24 pm
Piglet you got it half right
were those your jim jam's you were wearing :lol: :lol: :lol:
#165 PostAuthor: Al » Thu Jan 08, 2009 11:29 pm
Mark, Ray asked me to have a look at the Z and see what i could do.
Managed to find a couple of extra gee gee's.
It's going a little beter, no?
If you need me to do yours dont hesitate to ask.
See attached.
http://uk.youtube.com/watch?v=KeuInloXRZg
Not really.
I have tried to migrate my Santa Pod clips to Youtube to free up some space and because the original i posted of this was speeded up. Not by me but by the size of the clip or frame intensity!!! But it appears that if they have already been coded for another application then they will not transmit 'native'
I have no idea what the hell they are talking about but it does need fixing.
Great clip by the way. Well done that man. Santa Pod beckons.
Users browsing this forum: Bing [Bot] and 11 guests
