Fitting electronic ignition
Richardz900
#1 PostAuthor: Richardz900 » Thu Jan 01, 2009 4:22 pm
The HT lead has broken where it enters the coil on my z900 A4, i'v now decided to fit a Boyer Bransden Micro-Power CDI which includes new coils which i'll be ordering from z-power. Has anyone got any advice as to how to fit this myself? Or should it be taken to a garage to be done? I have basic knowledge and don't want to start the job if I cant finish it. Any tips will be appreciated.
Cheers :)
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Thu Jan 01, 2009 4:56 pm
Richard.
Just fitted a Dyna S system and 3 ohm coils to my Z1B,easy to follow instructions,can't go wrong,just make sure you fit some heat shrink tubing to the mounting bolts/spacers so LT side does not short to earth,pm me if you need some heat shrink tubing
Best Regards
Steve
Re: Fitting electronic ignition
#3 PostAuthor: Pigford » Thu Jan 01, 2009 4:59 pm
Richardz900 wrote:The HT lead has broken where it enters the coil on my z900 A4, i'v now decided to fit a Boyer Bransden Micro-Power CDI which includes new coils which i'll be ordering from z-power. Has anyone got any advice as to how to fit this myself? Or should it be taken to a garage to be done? I have basic knowledge and don't want to start the job if I cant finish it. Any tips will be appreciated.
Cheers :)
The general consensus on here is go DYNA everytime.... :??
I got a new DYNA S ignition for grabs.... :wink:
Boyer Branstonpickle systems don't seem to be too robust... :cry:
FER
Auld Heedyun
#4 PostAuthor: FER » Thu Jan 01, 2009 5:01 pm
Do not buy the Boyer system . Dyna everytime .
fer
wilsonsjw11
#5 PostAuthor: wilsonsjw11 » Thu Jan 01, 2009 5:02 pm
Mark
Can I be your marketing/promotions manager
Regards
Steve
Happy new year!!!!
#6 PostAuthor: Pigford » Thu Jan 01, 2009 5:03 pm
wilsonsjw11 wrote:Mark
Regards
Steve
Happy new year!!!!
Whats you % cut :?:
london calling
#7 PostAuthor: london calling » Thu Jan 01, 2009 5:03 pm
Piggy,I thought you had a Brand New Combine Harvester :lol: :lol:
Jack
#8 PostAuthor: Pigford » Thu Jan 01, 2009 5:05 pm
london calling wrote:Piggy,I thought you had a Brand New Combine Harvester :lol: :lol:
Jack-M-Lad..... But I won't give you the key :!:
london calling
#9 PostAuthor: london calling » Thu Jan 01, 2009 5:08 pm
Touche :wink:
Jack
#10 PostAuthor: Rich » Thu Jan 01, 2009 5:31 pm
If you can set points up it should be no problem for you to put elec ignition on. You will need a strobe and a basic idea of wiring would be an advantage.
#11 PostAuthor: Pigford » Thu Jan 01, 2009 5:36 pm
Intial set up, don't even need a strobe..... Manually hold on 'full advance' & check marks.... won't be too far out :wink:
Richardz900
#12 PostAuthor: Richardz900 » Thu Jan 01, 2009 6:25 pm
hi pigford, is the dyna s compleat with coils, if not what coils would i need. what u want for it. thanks for advice, regards & happy new year . richard.
#13 PostAuthor: Pigford » Thu Jan 01, 2009 6:30 pm
Richard....... sorry but I've been pm'd by a member who's just bought it off me...... :oops:
But Dyna S can be used with standard coils no probs... or Dyna Coils... 2.2 or 3.0 ohms :wink:
Richardz900
#14 PostAuthor: Richardz900 » Thu Jan 01, 2009 6:36 pm
wilsonsjw11 wrote:Richard.
Best Regards
Steve
thanks for advice steve. got some tubing but thanks, will fit it myself :?? regards & happy new year richard
Richardz900
#15 PostAuthor: Richardz900 » Thu Jan 01, 2009 7:00 pm
thanks to all for advice, :D dyna s its got to be. happy new year to all, richard.
Users browsing this forum: Google [Bot] and 19 guests
