is it possible...?
bunnysZ
Granny Magnet
is it possible...?
#1 PostAuthor: bunnysZ » Thu Dec 18, 2008 12:27 am
i have the 74 z1a with front brake pipe, is it possible to fit a braided brake pipe to this , to keep the original look. if so what parts are needed and where do you get them.
phil churchett
#2 PostAuthor: phil churchett » Thu Dec 18, 2008 9:54 am
Paul,
it's worth speaking to Braided Steel Aerotek, Chipping Camden, Glos.
Tel; 01386 849060.
It's run by Wendy Grant, [wife of the late Dave Grant], who was a big zed man.
Big Fluff
#3 PostAuthor: Big Fluff » Thu Dec 18, 2008 12:53 pm
Good shout Phil, though it's worth mentioning that you want 'swaged' ends as this will look much better.
Goodridge also deal direct to the public if you know who to talk to :lol: Try Vicky at vicky@k300.com
I paid just £76 for a set of 4 x clear coated, swaged, custom hoses with all st/st fittings & washers.
RALPHARAMA
#4 PostAuthor: RALPHARAMA » Thu Dec 18, 2008 2:26 pm
HEL brake lines are great with stainless used throughout. They will supply whatever you want with new stainless banjo bolts, copper washers etc. Whilst braided hoses are smaller in diameter than the original rubber lines you can have a black sleeve to keep the look to a degree. Never be tempted by alloy or plated mild steel fittings offered by other manufacturers. The 'kit form' braided lines are also a no-no!
You can buy direct from HEL ( http://helperformance.com/ ) or I can get them for you, as an authorised HEL dealer, and give you a 20% Z1OC discount :D
Ralph Ferrand
london calling
#5 PostAuthor: london calling » Thu Dec 18, 2008 5:34 pm
GREMLIN at Gremlin Racetech,he's in the links section.
Jack
Steve Cooke
#6 PostAuthor: Steve Cooke » Thu Dec 18, 2008 6:57 pm
I used Pirtek, they made up two lower lines and the upper in Goodridge black coated braided stainless,stainless fittings and Alu washers £45 all in.
#7 PostAuthor: Pigford » Thu Dec 18, 2008 7:13 pm
Also - Venhill....
I have used BSR Aerotek & they are bloody good :wink:
tlc
International Rep
#8 PostAuthor: tlc » Thu Dec 18, 2008 7:19 pm
But guys.........
Bunny wants to use the steel section going through the brackets.
I`m sure it can be done but it`s a pretty substantial flange :oops:
Asphalt Cowboy
Steve Cooke
#9 PostAuthor: Steve Cooke » Thu Dec 18, 2008 7:24 pm
Mine still uses the metal brake pipes to the calipers.
#10 PostAuthor: Rich » Thu Dec 18, 2008 7:57 pm
Do you mean keep the steel/kunifer pipe out of the caliper and then put stainless braided hose to that?
If so then yes it's possible Goodridge / Earls (Speed Seal) do all the adaptors and flange fittings. Had them on my T150V.
bunnysZ
Granny Magnet
#11 PostAuthor: bunnysZ » Thu Dec 18, 2008 10:00 pm
yes want to use the exsisting metal brake pipe.
I have the braided hose, need to know what bits i need to get to join to the metal pipe,
steve cooke could you post a pic if poss.
cheers
RALPHARAMA
#12 PostAuthor: RALPHARAMA » Thu Dec 18, 2008 10:44 pm
BunnysZ you need to get the braided hose made up to fit the fitting on the rigid hose. If you have a hose that hasn't got the correct fittings on it already then you will either have a rig of adapters or get the hoses remade corrcetly.
I personally hate rigid lines on motorcycle braking systems as there is always the issue of work hardening with vibration which leads to fractures which often leads to ... well ... err .... death :evil:
Ralph Ferrand
Steve Cooke
#13 PostAuthor: Steve Cooke » Fri Dec 19, 2008 5:07 pm
Here you go,
Users browsing this forum: Google [Bot] and 17 guests
