76 Turbo
RoyNorway
#31 PostAuthor: RoyNorway » Thu Aug 28, 2008 9:16 pm
Really nice!!
Thats really a nice piece of work that is! :roll:
Z1000J 82 model, and Z1000R 83 model, And The Calfshit-GPZ1100-
jus1975
#32 PostAuthor: jus1975 » Fri Aug 29, 2008 4:37 am
I'm I the only one not able to see the pics.
Kwakanut
#33 PostAuthor: Kwakanut » Fri Sep 05, 2008 5:22 pm
jus1975 wrote:I'm I the only one not able to see the pics.
They're over at CM also.
The top is done now.
#34 PostAuthor: Pigford » Fri Sep 05, 2008 6:44 pm
Ohhhhhhhhh My God.......
:hot :wub :hot :wub :hot :wub
:resp
Ed Z1-R
#35 PostAuthor: Ed Z1-R » Fri Sep 05, 2008 6:52 pm
Pukka machined parts :wink:
I must admit when parts a machined i just dig the finish,it spoils the component when it gets mirror polished :twisted:
davejames
#36 PostAuthor: davejames » Sat Sep 06, 2008 2:19 pm
What quality workmanship, they are beautiful. :D :D
Imagine what you'd pay for them "off the shelf" :shock: :shock: Doesn't even bear thinking about :shock: :shock:
Kwakanut
#37 PostAuthor: Kwakanut » Tue Sep 23, 2008 6:38 pm
Off the shelf they are almost twice what I'm paying. RF Biketech over in der Faderland sells 'em for 898 euro, which for me is about $1,300. Paul is charging me just under $800.
Meanwhile, back at the farm, the frame itself has been getting a little attention. Cleaning off the unneeded tabs and welding in the frame gussets.
tlc
International Rep
#38 PostAuthor: tlc » Tue Sep 23, 2008 7:24 pm
Nice bit of welding there.
I `spect it wasn`t windy that day ?
Asphalt Cowboy
02GF74
#39 PostAuthor: 02GF74 » Wed Sep 24, 2008 1:57 pm
nice welding - TIG or MIG?
how come the piccies in the early posts are not visible? :(
Kwakanut
#40 PostAuthor: Kwakanut » Thu Sep 25, 2008 12:34 pm
Crap! I moved some pics around in photobucket and the links got cut. I'll try to put them back. Meantime, here're a few more on the frame and with the ZRX arm fitted.
Kwakanut
#41 PostAuthor: Kwakanut » Thu Sep 25, 2008 12:41 pm
tailiftchris wrote:I `spect it wasn`t windy that day ?
haha. Nyet.
Pasc
#42 PostAuthor: Pasc » Thu Sep 25, 2008 12:53 pm
I like what you have done with the top shock mounts. Are they adaptors that thread onto the original mounts or have you also welded on new mounts ? Any more pics of them or drawings as I'm doing the same arm swap on my J.
Kwakanut
#43 PostAuthor: Kwakanut » Fri Sep 26, 2008 2:00 pm
It is a combo of spacers and special nuts. MMmmmmm....special nuts! Just like mine at home.. :lol:
I'll try to get more pics, and possibly drawings....
Pasc
#44 PostAuthor: Pasc » Fri Sep 26, 2008 2:20 pm
Cheers Kwakanut, I'd appreciate that.
Kwakanut
#45 PostAuthor: Kwakanut » Fri Sep 26, 2008 5:46 pm
Pasc, here is the response I got from the machinist....
"I retained the original shock tabs and left them in the original position. I ran a die over them to clean them up and to run the threads to the shoulder. then machined appropiate spacers, then machined special long sleeve shock nuts that fit inside the upper shock sleeve and to the appropiate length so that the shock stays put while allowing upper eye body clearence, the steel shock sleeve is slightly wider than the rubber bushing and shockbody eylet allowing movement
with out binding.......will send pic of what the shock nuts look like, you can see how I taper bored the outside of shock nut to the stud area so that there are no un sightly threads showing, the threads do go the width of the shock sleeve ......"
If you look at the 2nd to last pic in my last post with pics you can see what he's talking about with the threaded nut.
Users browsing this forum: Bing [Bot] and 5 guests
