Carb rubbers tip - Rock hard carb to airbox rubbers
Deac
A good tip before you throw your carb to airbox rubbers away and buy expensive new ones is to just get a couple of litres of cheap cellulose thinners, the gunwash type will do, get from any bodyshop supplier. Pour some into an old tin or better, a large glass so you can see whats happening.Tie a piece of wire round the rubbers so you can pull them out. Just simply drop your rubbers in, make sure they're fully submerged and leave them to pickle for 4 to 6 hours. I've even left them overnight, they wont dissolve! When you pull them out you might think that you've knackered em as they'll have swolen up to a lot bigger than they ever were. Just dry them off and leave a couple of hours, they should be nice and plyable and easy to fit. I've even done it with a complete Z1 airbox. Try it with an old spare rubber first, you've nothin to lose ! Should save you buying new ones and alot of sore fingers and cussing!
Deac
- Davy Doherty
- paul doran
Deac
- paul doran
