29mm carbs
29mm carbs
i think i have got a set of early 29mm smoothbore carbs,can anyone verify this for me somehow,bin on z1 carb site,they dont have 17mm nut underneeth,but they do measure 29mm,if they are,has anyone got any floats for them.
- RALPHARAMA
You really need to post some pix! There's a how to at the top of the discussion board. Then we can see what you're talking about, I know it's hard to start with but trust me it makes life a shit load easier in the long run
Ralph Ferrand
Re: 29mm carbs
hillbilly wrote:i think i have got a set of early 29mm smoothbore carbs,can anyone verify this for me somehow,bin on z1 carb site,they dont have 17mm nut underneeth,but they do measure 29mm,if they are,has anyone got any floats for them.
Pics would be good, also where are you taking the measurement on the carb?
WHO NEEDS DRUG'S
Here's an eBay auction link to some 29mm smoothbores. There are quite a few pics fro you to compare to your carbs.
http://cgi.ebay.com/ebaymotors/MIKUNI-2 ... enameZWDVW
Garden variety carbs described as 29 smoothbores. CAVEAT EMPTOR
http://cgi.ebay.com/ebaymotors/29-SMOOT ... enameZWD1V
Not all Mikuni sbores have a 17mm bottom plug, some of the early ones have a drain plug, I also have a set with plastic floats. What they do have is a slide that goes around the needle jet block giving a straight venturi and a combined needle jet and emulsion tube and there is only one casting for both left and right side carbs with redundant bosses left undrilled.
