Side panels and their fixing points
Lee McEvoy
#1 PostAuthor: Lee McEvoy » Fri May 23, 2008 8:25 pm
I have a modified Z900A4 frame, that appears to have had all the fixing points for the side panels removed (do not know why!).
Am trying to find any documentation / pictures or guidelines that show me what and where the original mounting points should look like and where they should be placed on the frame.
Garn 1
#2 PostAuthor: Garn 1 » Sat May 24, 2008 10:50 am
Lee, there are 6 points in all, three per side, where the Z900/KZ900-A4 side covers attach. From memory, two are an integral part of the engine mounting brackets and a third is in the battery retaining bracket, a fourth in in the plastic tool box. Which leaves two to be welded to the frame (RHS) I think.
I've just sold my A4, so I'll leave someone else to give you finite position measurements. You may have to buy some new rear engine mount brackets!
ludders
#3 PostAuthor: ludders » Sat May 24, 2008 1:34 pm
Hi lee i'ill try and post pics
did't work sorry i'll keep trying
z1a , z900 a4 , zx9r
ludders
#4 PostAuthor: ludders » Sat May 24, 2008 2:12 pm
Cant seem to get my head round it :star
if you PM me you'r email i'll send you pics :)
cra-z1
#5 PostAuthor: cra-z1 » Sat May 24, 2008 4:45 pm
I have an A4 battery box if you need one
Lee McEvoy
#6 PostAuthor: Lee McEvoy » Sat May 24, 2008 6:36 pm
Guys Thanks really appreciate your helkp on this. It looks like I could be fabricating lots of brackets (as It appears that not even my engine brackets are standard!!!.
Ludders PM to you this evening with my Hotmail account.
Suppose no one would have an old frame (no V5 necessary) and brackets that I could borrow to make the bits I would need to take side panels (which I do intend to by through the club).
Sawnee
#7 PostAuthor: Sawnee » Sat May 24, 2008 7:25 pm
Sorry cant help with a frame but if you are still after photos I can do some tomorow morning, :wink:
Lee McEvoy
#8 PostAuthor: Lee McEvoy » Sun May 25, 2008 10:57 am
Sawnee,
Cheers PM sent with email address.
Steve Cooke
#9 PostAuthor: Steve Cooke » Sun May 25, 2008 2:38 pm
lee whereabouts in Southampton are you? if you pm your number or address I could bring my Z900 frame and relevent brackets around to you so you can take some measurements/pics.
Iain marshall
#10 PostAuthor: Iain marshall » Sun May 25, 2008 3:20 pm
Lee might still have the side panel brackets i removed from one of my frames,will let you know tomorrow
ludders
#11 PostAuthor: ludders » Mon May 26, 2008 8:49 am
try againImage
ludders
#12 PostAuthor: ludders » Mon May 26, 2008 8:57 am
:cry:
Dark Skies
#13 PostAuthor: Dark Skies » Mon May 26, 2008 9:36 am
There you go chap. You just need to right click on the source photo, select properties and the true path will be displayed. Then just copy and paste within the Img brackets.
KZ1000-M1 CSR
ludders
#14 PostAuthor: ludders » Mon May 26, 2008 10:52 am
here goes againImage
ludders
#15 PostAuthor: ludders » Mon May 26, 2008 10:58 am
:swe :swe :swe :dead2
