switchgear help
Pasc
switchgear help
#1 PostAuthor: Pasc » Mon Mar 10, 2008 6:52 pm
Does anyone know if there is such a thing available as a switchgear internals repair kit for the z1000 a3/a4 ?
Ed Z1-R
#2 PostAuthor: Ed Z1-R » Mon Mar 10, 2008 11:42 pm
What EXACTLY do you need :idea:
Pasc
#3 PostAuthor: Pasc » Tue Mar 11, 2008 8:25 am
Ed, the starter button packed up. On stripping the switch I found the non metalic insulator that surrounds the starter button contacts had fallen apart in places allowing the contacts to short out against each other. It's basically just the piece that the wires attatch to that requires replacing. Everything else is fine.
#4 PostAuthor: Rich » Tue Mar 11, 2008 8:56 am
Is that the fibreboard part innermost, if you fancy making one let me know what thickness it is and I'll see if I have any that thick.
Pasc
#5 PostAuthor: Pasc » Tue Mar 11, 2008 1:36 pm
Rich, thats the one. I might take you up on your offer but as I'm not great with electrics and small fiddly bits I'll wait and see if I can find a replacement switch or internals. I'd guess its about 2-3mm thick and probably approx 10mm by 10mm squareish.
Hobbo
switch
#6 PostAuthor: Hobbo » Tue Mar 11, 2008 4:05 pm
PASC
GOT SOME OLD SWITCHES IN THE GARAGE WILL TAKE A LOOK TONIGHT
PHIL
Pasc
#7 PostAuthor: Pasc » Tue Mar 11, 2008 5:12 pm
Yer a star Phil. Ta very much. As I mentioned earlier I could get away with just the gubbins behind the starter button.
Thanks again.
Hobbo
switch
#8 PostAuthor: Hobbo » Tue Mar 11, 2008 10:20 pm
PASC
SORRY TO RAISE YOUR HOPES BUT NO JOY MUST HAVE GONE WITH THE CLEAROUT I HAD A COUPLE OF WEEKS A GO SORRY
PHIL
Pasc
#9 PostAuthor: Pasc » Wed Mar 12, 2008 5:39 pm
Thats Ok Phil, I think I've found a z650 switch on ebay that I can butcher for the bits I need.
Thanks for looking.
Ed Z1-R
#10 PostAuthor: Ed Z1-R » Thu Mar 13, 2008 12:27 am
Will have a shufti at the archives and let you know............
