Any help would be greatly appreciated!!
Engine Paint
- bulldogbobby
Engine Paint
The last rebuild on the Z1R included hours and hours of cleaning and rubbing down the engine and spraying it black. I was advised to use a paint called 'hot spot' which is a very high temperature paint designed for woodburners and stoves. Although it looked great at the time when it was finished, it's now gone a bit patchy and as I want to do it again (glutton for punishment) can anybody recommend anything else or have any tips on painting the engine??
- big green bus
- bulldogbobby
- big green bus
cra-z1
I agree with Dodgy, you need to make sure the engine is completly clean. Make sure you mask off all surfaces well. Do not put on heavy coats. Let it cure for a week or so. If you can find someone to bake it thats the best. If you can't only start the engine long enough to get it kinda hot at first. Keep on ramping up the length of run time on the engine to cure. The paint will continue to cure as you run the bike
g][/img]
