Piranha ignition query.
I need to double check the timing of my piranha ignition. Pigford has kindly offered some info on fully advanced degree info. Where I'm puzzled is, how do I know the actual trigger point ? Obviously I cant use a bulb or multimeter to indicate the firing point and there are no lights on the control box to indicate the firing point. The ignition has 2 adjustable eyes on a back plate for 1/4 and 2/3 and a trigger disc with a cutout to fire each pair of pots.
Ah ha, did think about that one but wasn't sure if it would be accurate enough. Cheers guys I'll give it a whirl.
Pigford, re the ironing. Just do what I do and only iron the bits that show. ie if the arms of a shirt are covered by a jacket just iron the front bit about 2 inches either side of the buttons. Jobs a good un.
- RALPHARAMA
I'm not a big fan of static timing. Get it near enough and then use a timing light. I haven't got one and unless I fall out with my mate John I can't see any reason to buy one! His is Snap-On - I only borrow the best!
Re ironing: better still don't wear anything that needs ironing. If the bride wants me to wear something that requires ironing .... I hardly ever take her out anyway, though I did offer to take her to the Bristol Classic Bike Show ... she declined
Ralph Ferrand
