Oh Cock!
Oh Cock!
#1 PostAuthor: warren3200gt » Fri May 06, 2016 3:54 pm
Current 650 build has come up against a snag. Its a 530 chain but has 900 a4 CMA's so needed a 530 900 rear sprocket. The only one available is a 47 tooth. So I compensated by increasing the front sprocket to keep the stock ratio the same. But this has caused a problem. The chain run now touches the Dresda Box section swing arm bracing. So tried a stock front sprocket to lift the chain a tad but it's still just scraping even with the rear shocks under load.
So my dilemma is 1, find a 36 tooth A4 rear sprocket for a 530 chain or 2, take a chunk out the swing arm brace.
Unless you bike builders can come up with a simpler alternative. which would be nice as taking a chunk out is a pain and a smaller diameter sprocket doesn't appear to be available.
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
garyd
#2 PostAuthor: garyd » Fri May 06, 2016 4:18 pm
How about a chain tensioner like the one Harris use?
Lift it up from below.
anyone got a photo?
garyd
#3 PostAuthor: garyd » Fri May 06, 2016 4:24 pm
Not exactly the one I was thinking of but it give you the idea.
https://uk.pinterest.com/pin/509962357778688027/
#4 PostAuthor: Pigford » Fri May 06, 2016 4:25 pm
Here's mine.....
By Monster Craftsman http://www.monstercraftsman.com/categories/Tensioners/
#5 PostAuthor: Ginger Bear » Fri May 06, 2016 4:31 pm
Chain tensioners....... http://www.monstercraftsman.com/
B&C or Talon should be able to make you a sprocket to fit your requirements.
B&C made me a 38 tooth 530 sprocket a few years back now. Infact it's still in it's original wrapping, unused, in the bottom of my tool box. :roll: :roll:
# 104
#6 PostAuthor: Ginger Bear » Fri May 06, 2016 4:32 pm
Looks like Piggy beat me to it. :lol:
# 104
#7 PostAuthor: zed1015 » Fri May 06, 2016 4:34 pm
6 bolts fixing?
Pretty much most modern Kawasaki's use the same fitting.
ZXR750/ZX9/ZX10R/ZX12R etc.
Most use 530 pitch so shouldn't be that hard to find a match.
Try JT here - The JTR448 goes down to 38 tooth so not far off.
http://www.jtsprockets.com/catalogue/model/5595
Some nice ally ones here go down to 36tooth but pricey
http://global.rakuten.com/en/store/bike ... /10362343/
Or you can buy piloted blanks from Dennis Trollop racing and drill your own bolt holes.
#8 PostAuthor: warren3200gt » Fri May 06, 2016 5:26 pm
Ooops error in original post, standard 650 is 42/530 so 6 hole with 42 tooth 98mm dia centre hole with 6 bolt 130mm c/l dia holes.
Can't find one on JT with the correct holes for a 530 chain
I like the idea of a tensioner though, kinda fits the bikes theme, if I can find a black/silver one that fits either the swing arm (50 x 25 box) or the bracing (40 x 20 box).
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
ADE
#9 PostAuthor: ADE » Fri May 06, 2016 8:02 pm
B&C made me one a while back
Ade
