Dyna wiring question
tlc
International Rep
#1 PostAuthor: tlc » Sun Mar 27, 2016 8:36 pm
I now have a spangly new Dyna2000 fitted.
On returning from my inaugural ride I noticed that the off/run switch does not function.
Could this be because the positive lead should be wired through that switch?
Asphalt Cowboy
#2 PostAuthor: Pigford » Sun Mar 27, 2016 9:08 pm
One thing to bear in mind is a good power supply - and personally I don't have 100% confidence in the "spark" power running up and down the wiring loom - via the kill switch :??
Unless you've got a new loom or better still a "Wired for George" type conversion.
#3 PostAuthor: ZedHead » Sun Mar 27, 2016 9:22 pm
Pigford wrote:One thing to bear in mind is a good power supply - and personally I don't have 100% confidence in the "spark" power running up and down the wiring loom - via the kill switch :??
What he said :D
tlc
International Rep
#4 PostAuthor: tlc » Mon Mar 28, 2016 6:00 am
Thanks Mark.
I'll do a relay mod.
Asphalt Cowboy
