Is it nuts and bolts or is cutting involved ?
How does it effect chain offset ?
On a similar theme what is the easiest USD forks to fit ?
Just asking like......
LeeJackson wrote:Ruddy
I'm just fitting one to my J. Waiting to get it back from powder coaters next week and I'll post some pics of what I'm planning to do to fit it. You can buy bronze bushings off the shelf to act like a spacer. I'm planning using these and changing the bearing for correct ID version, although closest you can get is one mm wider so need to see still how to fit that and get the circlip back in to retain it. Don't think it will be too big a deal.
Lee
