z1000st making progress and valve timing?
Desperate Stan
- Regular Poster
z1000st On the Road!
Havn't found the time to post for a couple of month's! first work took over then fishing!! chasing Coddies!.lol...well the bike passed its Mot straight thru,which was a relief.Quickly notched up a couple of hundred miles on the new pistons,what with the A338 being re-built started taking the back roads to work via Cranborne to wimborne etc ,nice ride first thing in the morning
.Didnt really have any issues,but with help from Debbens got some better inlet stubs for the carbs and also switched to a manual camchain adjuster as had doubt's about the original automatic one.[img][img]http://i1378.photobucket.com/albums/ah120/nohope37/frog%20plus%20biked%20and%20fish%20004_zpskuujhhyc.jpg[/img][/img]..
Hope to do more jobs over the winter ie switch gears,revamp clocks and tidy the loom which aint good but does work at least!..cheers Stan
Desperate Stan
- Regular Poster
Pigford wrote:Stan, looks real tidy![]()
Living in Sherborne, I often cut through Pimperne (via Sturminster Newton) then across to Cranborne/Horton, to Three Legged Cross and onto the A31 at Ringwood to head East, decent roads.
Thanks! ,may have to try that run one day ,my son is seeing a girl who lives in Sherborne!
Desperate Stan
- Regular Poster
cool oil
Hi all ,managed to get some money together after xmas and placed an order with webike in Japan,new oil cooler kit and a few other shiney bits,very pleased with their service etc and the quality of parts.Taken me a while to get it all sorted due to work and the dreaded lurgy that struck our household.
All fitted fine,I just made a simple plate to mount to frame and added some rubber washers to cushion thing a bit,however when having reused the old oil pressure switch it wouldnt work,a bit of head scratching and turned out the new oil port was slightly deeper internally and as a result the switch wasnt earthing inside,solved it by dismantling the switch and adding a extra washer to make it a bit longer.Also fitted a new fuel tap from z power,despite fitting new seals to my old tap it was still playing up,so far the new one seems to be spot on.With a half decent day yesterday I went for a spin,by the looks so did a lot of other people,saw a 250lc at the station,good to get out and hoping now with the whole summer a head I can clock up some miles.cheers Stan.
Desperate Stan
- Regular Poster
Desperate Stan
- Regular Poster
Desperate Stan
- Regular Poster
