z1000st making progress and valve timing?
Redbeard
#16 PostAuthor: Redbeard » Sun Aug 23, 2015 7:53 pm
Looks good Stan, I like the understated black. Enjoy the smooth power delivery..
1979 Z1000ST
#17 PostAuthor: ADRIAN H » Sun Aug 23, 2015 7:53 pm
Looking good. Nearly there.
Desperate Stan
z1000st On the Road!
#18 PostAuthor: Desperate Stan » Thu Oct 29, 2015 4:57 pm
Havn't found the time to post for a couple of month's! first work took over then fishing!! chasing Coddies!.lol...well the bike passed its Mot straight thru,which was a relief.Quickly notched up a couple of hundred miles on the new pistons,what with the A338 being re-built started taking the back roads to work via Cranborne to wimborne etc ,nice ride first thing in the morning :D .Didnt really have any issues,but with help from Debbens got some better inlet stubs for the carbs and also switched to a manual camchain adjuster as had doubt's about the original automatic one.[img][img]http://i1378.photobucket.com/albums/ah120/nohope37/frog%20plus%20biked%20and%20fish%20004_zpskuujhhyc.jpg[/img][/img]..ImageImage
Hope to do more jobs over the winter ie switch gears,revamp clocks and tidy the loom which aint good but does work at least!..cheers Stan
#19 PostAuthor: Pigford » Thu Oct 29, 2015 6:19 pm
Stan, looks real tidy :P
Living in Sherborne, I often cut through Pimperne (via Sturminster Newton) then across to Cranborne/Horton, to Three Legged Cross and onto the A31 at Ringwood to head East, decent roads.
#20 PostAuthor: ADRIAN H » Thu Oct 29, 2015 6:31 pm
Looking good. :D :D :D
Desperate Stan
#21 PostAuthor: Desperate Stan » Thu Oct 29, 2015 6:55 pm
Pigford wrote:Stan, looks real tidy :P
Thanks! ,may have to try that run one day ,my son is seeing a girl who lives in Sherborne!
Desperate Stan
cool oil
#22 PostAuthor: Desperate Stan » Sat Mar 26, 2016 10:11 am
Hi all ,managed to get some money together after xmas and placed an order with webike in Japan,new oil cooler kit and a few other shiney bits,very pleased with their service etc and the quality of parts.Taken me a while to get it all sorted due to work and the dreaded lurgy that struck our household.Image
All fitted fine,I just made a simple plate to mount to frame and added some rubber washers to cushion thing a bit,however when having reused the old oil pressure switch it wouldnt work,a bit of head scratching and turned out the new oil port was slightly deeper internally and as a result the switch wasnt earthing inside,solved it by dismantling the switch and adding a extra washer to make it a bit longer.Also fitted a new fuel tap from z power,despite fitting new seals to my old tap it was still playing up,so far the new one seems to be spot on.With a half decent day yesterday I went for a spin,by the looks so did a lot of other people,saw a 250lc at the station,good to get out and hoping now with the whole summer a head I can clock up some miles.cheers Stan.ImageImage
Redbeard
#23 PostAuthor: Redbeard » Sat Mar 26, 2016 10:39 am
Looks great Stan, oil cooler looks like it means business. Good to see another ST, not long now and mine will be Mot'd hopefully.
1979 Z1000ST
Desperate Stan
#24 PostAuthor: Desperate Stan » Sat Mar 26, 2016 10:59 am
Redbeard wrote:Looks great Stan, oil cooler looks like it means business. Good to see another ST, not long now and mine will be Mot'd hopefully.
Thanks!,im happywith it! :D ,good luck with yours!
#25 PostAuthor: Ginger Bear » Sat Mar 26, 2016 11:05 am
That's a tidy looking ST. :up
Be warned.........WeBike can be addictive. :save :save :save
# 104
Desperate Stan
#26 PostAuthor: Desperate Stan » Sat Mar 26, 2016 11:32 am
Ginger Bear wrote:That's a tidy looking ST. :up
Cheers,and yeah ur right about webike! think thats it for now tho!
#27 PostAuthor: Pigford » Sat Mar 26, 2016 2:31 pm
Have to meet up sometime..... you going to the Ace 17 April for Kawasaki Day :?:
Desperate Stan
#28 PostAuthor: Desperate Stan » Sun Mar 27, 2016 9:34 am
Pigford wrote:Have to meet up sometime..... you going to the Ace 17 April for Kawasaki Day :?:
Hi,ive always fancied a trip up there as ive never been! but not sure if i'll have enough free time yet,are there any local meets or rides coming up? cheers.
#29 PostAuthor: Pigford » Sun Mar 27, 2016 10:05 am
Nothing local I can think of :??
If something occurs I'll let you know.
#30 PostAuthor: kev edwards » Sun Mar 27, 2016 10:48 am
Hi Stan, was this bike running last summer, i ask because i'm pretty sure i see it at Alderholt, tried to follow it but it got away.
Users browsing this forum: Bing [Bot] and 6 guests
