Caliper Piston Sizes
Garn 1
#1 PostAuthor: Garn 1 » Tue Sep 08, 2015 10:06 pm
Could anyone tell me the caliper Piston diameter sizes of the following.
Kawasaki.
Z1...
Z900-A4...... 42.85mm
KZ900......
Z1000-A1.....
Z1000-A2.....
johny brando
Re: Caliper Piton Sizes
#2 PostAuthor: johny brando » Thu Sep 10, 2015 1:38 am
Garn 1 wrote:Could anyone tell me the caliper Piston diameter sizes of the following.
Kawasaki.
Z1...
KZ900......
Z1000-A1.....
Z1000-A2.....
Hi , I can only find Z1 a&b Piston dimensions in my Clymer manuals
Standard= 38.115 to 38.148mm (service limit 38.105mm )
Cheers, Johny Brando
Garn 1
#3 PostAuthor: Garn 1 » Thu Sep 10, 2015 4:23 am
Thanks Johny B, thats a good start.... Funnily enough I've found a set with bleed screws on the side (meaning they were for calipers mounted behind front forks) that are 38.15mm dia . So perhaps the Z1000 A2 has this dimension also.
johny brando
#4 PostAuthor: johny brando » Sat Sep 12, 2015 8:18 am
Garn 1 wrote:Thanks Johny B, thats a good start.... Funnily enough I've found a set with bleed screws on the side (meaning they were for calipers mounted behind front forks) that are 38.15mm dia . So perhaps the Z1000 A2 has this dimension also.
Just checked out my mates Z1000 A1 " Factory " work-shop manual .
It states.... Front & Rear caliper piston dimensions are exactly the same :
Piston O/D = 42.788mm - 42.880mm (Service limit= 42.75mm )
Johny Brando.
Garn 1
#5 PostAuthor: Garn 1 » Sat Sep 12, 2015 2:19 pm
Gent's here is a pretty definitive answer to my queries...........
Z1 Z1A Z1B - 43mm X 34mm.
Z900A4 Z1000A1 and KZ - 43 X 40.
Z1000A2 Z1R D1 and KZ - 38 X 40.
Z1R D2 D3 and KZ - 43 X 41.
REAR Z1000A1 A2 Z1R D1 - 43 X 22.
REAR Z1R D2 D3 - 43 X ??
ps interesting to note Kawasaki round of to the nearest lower number - 42mm, all listing outside Kawasaki round of other side - 43mm.
pss interesting to note some listings on FleaBaYe/online have many incorrect sizes.
This is from the man from Mandura West Australia. He disagrees with our statement on Z1, Z1A & Z1B.
RegardZ
Users browsing this forum: Bing [Bot] and 13 guests
