z1000A1 swinging arm
flateddie
#1 PostAuthor: flateddie » Sun Aug 30, 2015 3:56 pm
Hi Guys,
Anyone know the width of a z1000 A1 or A2 swinging arm at the wheel spindle? mine came with cast wheels, scored a pair of spoked wheels but my swinging arm is a far too wide with the standard wheel spacers. My swinging arm is 245 mm so think it may have came from a J model like the wheels.
000zeds
#2 PostAuthor: 000zeds » Sun Aug 30, 2015 4:31 pm
The sprocket carrier hub section is not interchangeable between spoke and cast wheels due to different width so this could be your problem !
Zeds-R-Us
flateddie
#3 PostAuthor: flateddie » Sun Aug 30, 2015 5:14 pm
hi there I remember seeing that somewhere and sure enough on mine the bosses on the carrier are a different profile to the cush drive on the spoked wheel , when i stripped the bike and took off the cast wheel a load of washers fell out with the spacers and when I bought the spoked wheels they came with the sprocket carrier. I found an old post where someone was looking to fit wider wheel to a z1000 and he had 7 and 1/2 " from the swinging arm to the brake carrier mine is more like 8 and 1/2". I have fitted a zephyr 1100 front and back end and just getting all the standard gear together in storage to return to standard at a later date
Z1parR
#4 PostAuthor: Z1parR » Sun Aug 30, 2015 5:34 pm
Just been out and measured my Z1R swinging arm .
The wheel is still in so this measurement could be a midges out at 223mm .
0172 . Geoff Parr
flateddie
#5 PostAuthor: flateddie » Sun Aug 30, 2015 5:42 pm
thanks a lot for that, confirms my suspicions going to have to source a 1000A swinging arm cheers guys
Steve Cooke
#6 PostAuthor: Steve Cooke » Tue Sep 01, 2015 5:50 pm
The one hanging on my wall measures 227-228mm from an A2.
#7 PostAuthor: ADRIAN H » Tue Sep 01, 2015 8:10 pm
Steve Cooke wrote:The one hanging on my wall measures 227-228mm from an A2.
+1
