Carb Tune
I can do this but I have conflicting information on how to set them up from the manuals I have.
My bike doesn't have the throttle stopper and I can work out what is meant by "in the middle" I know why so you have adjustment either way.
If I can get the valves near perfect the rest I can take up with the carbtune.
Bike now finished what a joy!
Wayne1960 wrote:I can do this but I have conflicting information on how to set them up from the manuals I have.
You don't have a throttle stop or stop screw, if not you are on a hiding to nothing, are you able to put some pics of your carbs on here, if not email them to me. PM sent
if you look a this slide the notch you are looking for is in the 12 o clock position in the photo to do this procedure you have to remove the carbs from the engine as the notch is facing the engine. i don't know where you have got your 2mm measurement from ?
http://www.ebay.co.uk/itm/KAWASAKI-NOS- ... 35edd4a1b6
hi Z1 i have sent some pics and waiting for a reply. i have taken loads of pics of the throttle slide, and thanks for link, but mine clearly doesn't have the notch!!!!!!!
i can clearly see the one in the pic but mine, well carb 1 clearly doesnt have it.
ok i really do understand what you are saying but i have taken pictures inside the carb and can see all round the needle and it looks exactly like the one Z1 sent the link with the same holes and id but not notch.
