Anyone got a new front hub seal (speedo drive side). Part no. 92050-046.
Front brake not working too well as the disc is being sprayed with grease on a long run. Stops the brake squeaking though !!
Is there any special grease required for the speedo drive or is the standard castrol stuff ok as I seem to have it coming out of the seal and speedo cable fitting a the wheel end since I cleaned and re greased it?
Cheers Steve
Z1 Front Hub Seal
- wheelysteve
Z1 Front Hub Seal
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
- wheelysteve
- wheelysteve
The markings on the seal show:
BJN-C2 54 65 6
Which I take to mean it's a 54mm internal dia, 65mm external dia and 6mm seat width. I can't find this size listed in the searches I've done. Is it a one off size for the Z ?
BJN-C2 54 65 6
1975 Z1B Candy Red
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
1975 Z1B Candy Blue
1975 Dogs Z1B
1977 Z650B1
1978 Z650B2
H***a Blackbird
PUM 710
- wheelysteve
Apologies I misunderstood the seal. I thought it to be the seal inside the hub. Also I have an A4 which looking on CMSL was a different part number even for that seal. Mine was 17x23x3mm Nitrile Rubber Metric Oil Seal.
I looked on Simply Bearings Website and your seal does not appear to be a common size.
LE to JOG on a z900
P.U.M.
P.U.M.
Users browsing this forum: No registered users and 5 guests
