left hand switch?
ogre
left hand switch?
#1 PostAuthor: ogre » Thu Apr 30, 2015 10:00 am
hi all can anyone tell me what this switch is off .took it off my z1a been messed with the dates correct but i thought they just had the white arrows on this date.cheers
Coose
#2 PostAuthor: Coose » Thu Apr 30, 2015 10:10 am
It looks to be a tad later. By the looks of things my J has switchgear from a US-spec ST, which looks to be identical to that but with a hazard lights switch.
ogre
#3 PostAuthor: ogre » Thu Apr 30, 2015 10:15 am
cheers for that but the date looks like jan 74.
CAT3
#4 PostAuthor: CAT3 » Thu Apr 30, 2015 4:14 pm
Has the HORN/PASS button been modified by having the extended section on the PASS side removed ?
If it has then your L/H switch assembly is identical to that fitted to the 1976 Z900-A4. The colours of the lettering, yellow & white is correct, certainly for that year too.
KWACKERZ1
#5 PostAuthor: KWACKERZ1 » Thu Apr 30, 2015 4:17 pm
Date is on the bottom half perhaps the top was changed and re-wired.
But I have never owned an Anorak!! so don't know about z1's :lol:
ogre
#6 PostAuthor: ogre » Thu Apr 30, 2015 6:31 pm
doesnt look to av been modified but the button feels like it has bottomed out on the pass side just wondering if its off a h1 or h2
steve bowdler
#7 PostAuthor: steve bowdler » Thu Apr 30, 2015 6:40 pm
My 77 z1000 ltd had a similar switch unit no pass facility
keith mayall
swith
#8 PostAuthor: keith mayall » Thu Apr 30, 2015 6:42 pm
ive just checked my z1b and a4...the switch looks like the z1b.
davejames
#9 PostAuthor: davejames » Fri May 01, 2015 12:04 am
Sure my B is the same and has a build date of Sep 74 with frame and engine nos in 56000 range. Would Jan 74 be too early for that type of switch?
garyd
#10 PostAuthor: garyd » Fri May 01, 2015 7:54 am
Guess it's not impossible for Kawasaki to have a stores problem and found a box of bits and just slung them into the production line.
They did tend to use whatever they had at the time.
Did I tell you many years ago I stripped the paint off a Z1A to find the green/yellow of the Z1 underneath.
Users browsing this forum: Google [Bot] and 19 guests
