Z1-R rear brake hose length & fitting - HELP
pertonpc
#1 PostAuthor: pertonpc » Fri Mar 06, 2015 6:34 pm
My Z1-R came with modern brake lines and I want the standard look -
I have just done a test fit on my new rear brake hose.
I have checked which way the unions go against the Z1-R sales brochure so I think they are the right way round ??
The only way I can get it to join up is to route it like this -
Can anyone with an original Z1-R rear hose fitted tell me if this looks correct or send me a pic of the entire hose run so I can see where I am out.
Would appreciate the measurement of rubber hose showing between the two unions if anyone has an original they can check. This one is the PMC part listed for Z1-R 1978 but I think it looks a little long on the bike.
I know I need the two rubber grommets for the swinging arm hooks - I had hoped they would come with the hose but no such luck :cry: :cry:
Thanks for looking
#2 PostAuthor: z1bman » Fri Mar 06, 2015 7:01 pm
57cm according to this genuine hose on e bay
http://www.ebay.co.uk/itm/Kawasaki-KZ10 ... 1295412950
pertonpc
#3 PostAuthor: pertonpc » Fri Mar 06, 2015 7:58 pm
Thanks Paul
My bike is Z1-R D1 1978 so the brake hose is 43059-1006
The 1046 in the eBay ad is for the later D3 1980 model
Not sure why they changed - perhaps D3 has different rear master cylinder ??
Any how I need measurement off a D1 or 1006 hose to be sure.
Or someone to tell me that the two hoses are the same length ??
This pic is from the Z1-R sales brochure -
Cheers from Mark
#4 PostAuthor: z1bman » Fri Mar 06, 2015 8:38 pm
yes your rite mark d3 hose is bolted to the top of the master cylinder
compo z1r
#5 PostAuthor: compo z1r » Fri Mar 06, 2015 8:53 pm
d1 hose is 42 cm or 420mm to u :wink: + banjo's
d3 hose
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
pertonpc
#6 PostAuthor: pertonpc » Fri Mar 06, 2015 9:06 pm
Thanks Neil,
So it looks like the one in the eBay advert could be for a D1 - as it has a full length spring.
I will drop mine off tomorrow and get it measured properly.
DavidZ1R
#7 PostAuthor: DavidZ1R » Fri Mar 06, 2015 9:14 pm
Kin ell Neil beat me to it
pertonpc
#8 PostAuthor: pertonpc » Fri Mar 06, 2015 10:41 pm
Thanks David,
Could you just check length of rubber hose visible between unions and see how close you are to Compo's 420 mm please ??
Ta from Mark
compo z1r
#9 PostAuthor: compo z1r » Sat Mar 07, 2015 12:49 pm
pertonpc wrote:Thanks Neil,
not at 570mm its from summit else :shock:
Z1OC # 886
pertonpc
#10 PostAuthor: pertonpc » Sat Mar 07, 2015 9:42 pm
I got my new hose off and measured visible hose between unions.
I got 480 mm
I think that means mine's bigger than Compo's :oops: :oops:
It's interesting that neither of the D1s in the pics sent in have the hose looping below the bottom of the torque arm linkage like the Z1-R brochure picture.
Thanks for all the help people
from Mark
#11 PostAuthor: z1bman » Sat Mar 07, 2015 10:14 pm
don't no whether this is relevant but the pmc site shows a picture of the d3 & they would be about 50mm longer as the hose fitting is fitted to the top of the master cylinder ?
compo z1r
#12 PostAuthor: compo z1r » Sat Mar 07, 2015 10:18 pm
pertonpc wrote:I got my new hose off and measured visible hose between unions.
I got 480 mm
from Mark
mark just had a look through tony sculpher's book on the z1r and the dealer pic shows it above the linkage sorry to b a pain :wink:
Z1OC # 886
pertonpc
#13 PostAuthor: pertonpc » Sat Mar 07, 2015 10:39 pm
Cheers Neil
I will check my Tony book too, I'm pretty sure PMC listed different nos. for the D1 and D3 rear hose but I need to check now - and make sure I got sent the right one.
Mine would be long enough to go to the top of the master cylinder - which makes it sound like a D3 hose.
How long is your D3 hose between unions ?? if it is 48cm like mine then that would be interesting.
