Hi chaps.
I'll soon be round to getting my outer engine cases powder coated and need some help.
Is it really necessary for the coaters to blast prepare the surface and how thin have you asked them to coat.
How have you successfully masked the oil sight window.
The reason being is the cases are in perfect condition but some were painted by the engine builder so will at least need cleaning.
I suppose also at the end of the day is powder coating the best way to go with engine cases ?
Powder coating engine cases.
Asphalt Cowboy
The cases need to be blasted (although not aggressively) to etch the surface as a key for the powder.
The powder coat won't stick properly to smooth surfaces and will easily peel off.
Masking of the sight glass orifice shouldn't be a problem for a good coater.
Personally I wouldn't powder coat as any damage or imperfections in the finish is near impossible to correct and will stand out a mile.
I've just spent weeks stripping a set of powdered cases which had corroded under the surface and started to bubble and peel.
yo
As for thickness too much will chip easy too little will look crap a good powder coater should know the thickness scale which is 0.65-0.85 microns usually baked 210 deg for around 10mins . Smooth clean surfaces will coat well/better if applied and baked properly
phil
phil
Just had my Katana 1170 engine blasted and powder coated and they are mint, any powder coater that knows what they are doing will know how to do them, I had mine done at Maldon powder coating and as I said they have come out mint
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
Ducati 1198R Race
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
- big green bus
