Rocker Cover Removal
Farmer
#16 PostAuthor: Farmer » Fri Feb 06, 2015 10:09 pm
Well tonight I got the pesky thing off, I think the previous American owner used a whole tube of silicone on it, I will check tomorrow the valve clearances, looking in the manual the special tool looks different to the valve clearance guide :??
1981 KZ1000 K1 LTD
mick znone
#17 PostAuthor: mick znone » Fri Feb 06, 2015 10:17 pm
hope it isnt warped or some such, makes you wonder why he used 3 kg of silycone. :shock:
Farmer
#18 PostAuthor: Farmer » Fri Feb 06, 2015 10:25 pm
I was going to put it on a pane of glass with a sheet of fine emery paper and see where it goes. :)
1981 KZ1000 K1 LTD
mick znone
#19 PostAuthor: mick znone » Fri Feb 06, 2015 10:33 pm
:up :D
#20 PostAuthor: Al » Sat Feb 07, 2015 12:10 am
Replied in shim thread.
Might be a good idea to remove the oil filter if not the sump as that nasty stuff has a habit of drawing to the oil feed pickup below the oil pump!
Are you ready for us to send Jim the 'traveling mechanic' yet?
He has a boat full of seamen that he smokes about in! :shock:
#21 PostAuthor: Ginger Bear » Sat Feb 07, 2015 7:24 am
I'd have the sump off to be sure. It might look like this.......... :shock: :shock:
# 104
jimmock
#22 PostAuthor: jimmock » Sat Feb 07, 2015 10:04 am
GB,
I've NEVER seen anything like that in my life before!!!
Jimmock. :wnkr
I hate people I don't like !
Z1parR
#23 PostAuthor: Z1parR » Sat Feb 07, 2015 2:32 pm
GB has quite a few unusual looking parts :lol:
0172 . Geoff Parr
Farmer
#24 PostAuthor: Farmer » Sat Feb 07, 2015 5:42 pm
Bleeding ell, what state was the rest of the engine in ? :shock:
1981 KZ1000 K1 LTD
Farmer
#25 PostAuthor: Farmer » Sat Feb 07, 2015 6:06 pm
zorded wrote:Replied in shim thread.
Only if hes bringing an Alfa exhaust to fit, then he might as well do the sump job as well :lol:
1981 KZ1000 K1 LTD
Farmer
#26 PostAuthor: Farmer » Sun Mar 29, 2015 12:54 pm
The rocker cover came off surprisingly easy although I found another stripped thread, after reading Pigfords post on some American forum I found myself on one evening I voted for buying 1/4 allen bolts for the two stripped ones, it worked a treat and with some thinner shims it all went back together nicely. :D
1981 KZ1000 K1 LTD
#27 PostAuthor: Pigford » Sun Mar 29, 2015 1:41 pm
Farmer wrote:... after reading Pigfords post on some American forum .... :D
:?? Huh :?:
Farmer
#28 PostAuthor: Farmer » Sun Mar 29, 2015 2:46 pm
It was some American Kawa forum and the thread was about stripped threads, I think it was a few yrs ago now. It was a Pigford from England so I assumed it was you. :)
1981 KZ1000 K1 LTD
#29 PostAuthor: Pigford » Sun Mar 29, 2015 3:40 pm
Farmer wrote:It was some American Kawa forum and the thread was about stripped threads, I think it was a few yrs ago now. It was a Pigford from England so I assumed it was you. :)
Probably - I do get around a bit :oops:
