Have just purchased an A4 which I am in the process of doing a complete strip and re-build on.
With the engine not running I can select 1st and back to neutral without any problem but it is not possible to select any of the higher gears
With the engine running all gears are selectable? Is this normal?
I am only planning to do a top end strip, head and barrel and don't want to be splitting cases. Any suggestions?
Gear changing
- steve bowdler
sprint wrote:Thanks for replies.
Very strange arrangement, never come across that with any other bike. Must be a reason?
But at least I don't have to worry about it and have to spit the cases.
At least you asked before turning the bike upside down and removing the sump, then scratching your head for two hours, then giving up and asking on here
1976 KZ900
1976 KZ900
