Parts wanted for A4
Parts wanted for A4
I am seeking a couple of parts for a Z900A4.
1. A complete 5/8" front brake master cylinder for twin discs. The type I am looking for has the solid aluminium body and the flat top cap with the stick on decal.
2. Pair of seat hinges. These are the type that have the handed (mirror image) brks spot welded to one side and are used with the 'L' shaped hinge pins, as shown in the link.
https://www.google.co.uk/search?q=kawas ... 1976-model).aspx%253Fp%253D%3B640%3B480
EFFAA410000P
EFFAA-410-000P
Go to David Silvers website and search for above part numbers,direct link dont work,its a master cylinder for a cb750 f2 same as a a4,
Used these before look the same and work well ,good price too...
EFFAA-410-000P
Z1b man you have the link for the single caliper jobby,part numbers i have listed is for the Twin caliper for some reason the direct link to it wont work on Silvers Site!...Paul J
Thanks for reply and link.
It is my understanding that the earlier Z1's used the master cylinder with the dome cap with the cast lettering but the A4 used the type which had the flat cap with the stuck on decal as in the link? It is also my understanding the caps are not interchangeable?
http://www.ebay.co.uk/itm/131269488671? ... EBIDX%3AIT
z1bman wrote:https://www.z-power.co.uk/merchantmanager/product_info.php?products_id=697
Thanks for the reply and link.
I had seen these on the Z-Power site but they have the side brk on the same side instead of being handed? Not really a major problem but would like to get the handed ones that were fitted originally if I can as in the link:
https://www.google.co.uk/search?q=kawas ... i-z900-a4-
easy enough to modify i would grind of the spot weld & weld it on the opposite side
http://www.z-fever.de/ShopNeu/shop/show ... ri2kkal9a1
This the DS link for the £29 version which they list as being 14mm so only suitable foe single disc?
https://www.davidsilverspares.co.uk/CB7 ... rt_123912/
My understanding was they they only do this MC in the in the one size, 5/8" so is DS just simply charging more for the same part because it is sold for a twin disc?
sprint wrote:This the DS link for the £29 version which they list as being 14mm so only suitable foe single disc?
it says in the description for dohc & twin cylinder m/c & not twin disc?
Users browsing this forum: Bing [Bot] and 8 guests
