metmachex ,piggy back shockers ans rear torque arm
stempy
#1 PostAuthor: stempy » Sat Jan 10, 2015 4:47 pm
Has anyone made an adjustable torque arm for a Z1000
Wanted to fit my marzocchi shockers with the piggy back at the swinging arm- facing towards the rear but the rear calliper torque arm fixing is in the way so I was considering putting a longer torque arm in to get round the problem?
PUM 451
#2 PostAuthor: Pigford » Sat Jan 10, 2015 5:21 pm
I used some M8 s/s studding, a couple of suitable rose-joints (eBay)... cut to length as needed then got some 10mm dia alloy tube and cut to cover all the studding... worked & looked good.
NB: Brake forces put studding in tension, not compression
stempy
Arm
#3 PostAuthor: stempy » Sat Jan 10, 2015 6:42 pm
Might need it a bit stronger as it will be compression
PUM 451
#4 PostAuthor: ADRIAN H » Sat Jan 10, 2015 7:02 pm
stempy
#5 PostAuthor: stempy » Sat Jan 10, 2015 7:10 pm
Adrian
Now that rear caliper and bracket looks the dogs ,do you have any spare :D
PUM 451
Re: .
#6 PostAuthor: ADRIAN H » Sat Jan 10, 2015 7:22 pm
stempy wrote:Adrian
bought the hanger and wheel spacer from webike japan
http://japan.webike.net/products/1522732.html
http://japan.webike.net/products/1522031.html
the caliper - Bembo P108 ( has same centres as AP C2696 which the hanger was made for) was bought from
http://www.mdinaitalia.co.uk/cgi-bin/co ... egory=BVBR
#7 PostAuthor: Ginger Bear » Sun Jan 11, 2015 12:55 pm
Rick,
As promised, details of my 'Toast Rack' torque arm.
Bought a length of 3/4" aluminium bar, turned some of the excess from the middle, leaving plenty of meat at the ends. Drilled & tapped M12 thread each end to suit M12 Rose joints. (Both R/H thread, so cannot be adjusted on the bike.)
I used M12 joints, as the mounts on the swinger & caliper are both 12mm.
Gotta say though, I do like Adrians solution, pretty much "plug 'n play" and no machining...... In fact, I'm off to have a little browse in that sellers shop. :wave
# 104
stempy
cheers GB
#8 PostAuthor: stempy » Mon Jan 26, 2015 7:19 pm
Thanks to GBs pictures made one in the end
PUM 451
Charlie
#9 PostAuthor: Charlie » Wed Jan 28, 2015 6:11 pm
I have the same swingarm/shock setup on my Z650, although I prefer the shock reservoirs facing forwards.
I used an aftermarket GSF1200 stainless torque arm on mine. That was longer than the stock and nasty looking stock torque arm.
