K&N type filter cleaning
Guyz do you need the branded type filter cleaner that K&n sell plus the oil,or will anything else do the trick?..Ta
I cleaned mine with petrol and then purposely didnt spray on any dust attractor with the specific intention of doing it regularly and not cutting down on air flow through the filter.
Drifting away from the CV's for a bit now so will see how the K&N behaves with slide carbs. May use a different regime for those.
snotie1965
Hmm thought the idea behind the oil was to add an extra dimension to filtering by trapping the tiny bits that the filter medium missed, or am I missing a point ?
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Not missing anything Keith, after a year of running it 'wet' when new it didnt collect any dirt but loads of leaves, flies, bits of foam from the seat, lint, seeds and a fibre washer.
Oil wont help these in future but does have the effect of holding them against the surface of the filter and clogging it.
Mine is a K&N direct replacement filter used inside the standard airbox.
Like the WD40 idea though.
snotie1965
I thought you meant single wire mesh type filters ? i would contact K&N and 1st see if it is a washable type ? if not get a new one ?zorded wrote:Not missing anything Keith, after a year of running it 'wet' when new it didnt collect any dirt but loads of leaves, flies, bits of foam from the seat, lint, seeds and a fibre washer.
My mate years ago at Long marsden ran his Z1B with a K&N air box filter and only got high 12`s he took it out and ran 12.02 ,so it is quite important to get it right ?
