UNLIMITED LTD - The Pigford Project
freddyz1r
#46 PostAuthor: freddyz1r » Sun Nov 02, 2014 11:44 pm
You're not hanging about. At this rate piggy you'll be riding it next week :shock:
keep it up :up :pop
cheerz freddy :D
“It's not me who can't keep a secret. It's the people I tell that can't.â€￾
freddyz1r
PUM 329
#47 PostAuthor: Pigford » Mon Nov 03, 2014 7:20 am
So'kay with the braided cables, they're clear plastic sleeved - thanks anyhow :wink:
freddy - Time & Ride wait for no man :shock:
needaz1100r
#48 PostAuthor: needaz1100r » Mon Nov 03, 2014 10:19 am
Pigford wrote:So'kay with the braided cables, they're clear plastic sleeved - thanks anyhow :wink:
I looked hard at the pics but couldn't tell - you're obviously wise to the problem.
Mark.
#49 PostAuthor: Pigford » Mon Nov 03, 2014 6:28 pm
Dummy run with the JMC swingarm.....
Gap in frame is 235mm - swingarm is 215mm..... so 10mm spacers required each side. Also the original wheelbase is the same with it adjusted up to the max, with +125mm further adjustment as the chain wears :lol:
All lines up well, even the shock mounts are same spacing. Only thing is the rear footrest hangers are in the way :roll: So it'll be out with Mr Grinder at the weekend :twisted:
#50 PostAuthor: Ginger Bear » Mon Nov 03, 2014 6:31 pm
Pigford wrote: So it'll be out with Mr Grinder at the weekend :twisted:
I knew it was only a matter of time. :eek :eek
# 104
#51 PostAuthor: Pigford » Mon Nov 03, 2014 6:34 pm
I was trying to resist, but it was inevitable I suppose :roll:
sanderz
#52 PostAuthor: sanderz » Tue Nov 04, 2014 8:54 pm
Proper swingarm :up
Good to hear the grinder will be out - you know it makes sense :)
Wots up DOHC
#53 PostAuthor: Pigford » Wed Nov 05, 2014 7:22 am
sanderz wrote:Proper swingarm :up
Only thing is knowing where to take the first cut :shock:
freddyz1r
#54 PostAuthor: freddyz1r » Wed Nov 05, 2014 7:27 am
Just remember, "the first cut is the deepest" :rap
:oops: I've got my coat :oops:
Freddy :D
freddyz1r
PUM 329
mick znone
#55 PostAuthor: mick znone » Wed Nov 05, 2014 7:34 am
freddyz1r wrote:Just remember, "the first cut is the deepest" :rap
Freddy :D
#56 PostAuthor: Pigford » Sun Nov 16, 2014 4:08 pm
Thought I'd get a bit more time in the garage, but only had an hour or so..... had to reverse the brake arm but it's good to go :!:
Also fitted the 33t sprocket - got a new front one to match 15t and a new chain ready to fit.
The yoke & handlebars are now swapped over with new r/hand switch gear...
Front end is complete with LTD fender & Teleflex brace...
Next is to sort out a stripped cam cap thread with a helicoil then I can start her up & get the 29mm Smoothies dialled in :twisted:
coldsummer
#57 PostAuthor: coldsummer » Sun Nov 16, 2014 4:47 pm
Looking good Mark, apart from the schoolboy error of putting the front muddy on backwards :shock:
#58 PostAuthor: Pigford » Sun Nov 16, 2014 6:37 pm
coldsummer wrote:Looking good Mark, apart from the schoolboy error of putting the front muddy on backwards :shock:
Thats the correct way Simon :lol:
coldsummer
#59 PostAuthor: coldsummer » Sun Nov 16, 2014 6:58 pm
No it's not :P
coldsummer
#60 PostAuthor: coldsummer » Sun Nov 16, 2014 7:01 pm
Well I think it looks better the other way :P
