cam chain guide sprocket
kwaka
#1 PostAuthor: kwaka » Thu Dec 13, 2007 8:16 am
G'day all, I'm not sure whether i should replace the cam chain guide sprockets on my Z1B. They look OK but i dont have a new one to compare with mine. Are they a part that is subject to wear? I'll try to add a photo if i can work it out :?? [imImageg][/img]
longhair
#2 PostAuthor: longhair » Thu Dec 13, 2007 1:19 pm
That bit is shot for sure ,you can see the cracks in the nylon,now is the time to replace this,if you want accurate valve timing.
http://z1enterprises.com/
http://www.schnitzracing.com/
cra-z1
#3 PostAuthor: cra-z1 » Thu Dec 13, 2007 4:20 pm
As a general rule I would replace as much items as I could while I have the engine apart. Chain, guides, rollers, ect. Go to Z1 enterprises site and look at the liska rollers/guides. Also go with the heavy duty chain. You do not want to pull the engine apart again because of a roller that could have been replaced.
kwaka
#4 PostAuthor: kwaka » Thu Dec 13, 2007 11:53 pm
The back and fronk guides are a different size ie. the front one has a larger bearing and a collar that fits over it's shaft, is this original or do you think these have been changed at some stage?
this is the front guide
and this is the rear one
Garn 1
#5 PostAuthor: Garn 1 » Fri Dec 14, 2007 2:47 am
Kwaka, I've pulled many Z1.. Kz900 down. I believe they should be the same size. The size I have always seen is the one without the sleeve.
It would be good to know if the other ones (larger bearings) are available, however, I think someone has been innovative and borrowed one from another make/model and had the sleeve ground to suit a bigger bearing.
When condemning these sprockets, I look for breakdown in the rubber bonding between the sprocket teeth and the bearing outer. Its very hard to pick on the top sprocket as it is shielded from view by the mounting bracket frame.
RegardZ
kwaka
#6 PostAuthor: kwaka » Fri Dec 14, 2007 7:03 am
Yeh i suppose i'll replace them both what the hell it's only money, only wish i had more of it. Thanks for the wisdom fellas.
KWACKERZ1
#7 PostAuthor: KWACKERZ1 » Fri Dec 14, 2007 2:18 pm
Have a look at z-enterprises as teh $-? ratio makes their stuff good value at present.
#8 PostAuthor: Rich » Fri Dec 14, 2007 5:28 pm
They should both be like the rear one. Kawasaki fitted rubber dampers in them to quieten the camchain down. If you want accurate timing but noisier go for the Liska ones, if you want it quieter go for original ones, Looks like they will all want replacing along with the camchain as someone has already had the front one break up.
#9 PostAuthor: Pigford » Fri Dec 14, 2007 5:41 pm
I think Suzook GS rollers fit, so that maybe wot it is :?:
Z1RII
#10 PostAuthor: Z1RII » Tue Dec 18, 2007 12:58 pm
first roller is definatly not stock kawasaki, the bearing is SKF aftermarket, since the stock kawa size is 10mm and this size is not standard. only 11mm inner size is available. i tried this out many times.
roll on!
amir
