gpz1100b1
big green bus
gpz1100b1
#1 PostAuthor: big green bus » Sun Nov 09, 2014 5:44 pm
has anybody got a wiring diagram or help me with the wiring on my B1 I want to fit the side stand cut out, but cannot find any where to plug it in and cannot find anything in the work shop manual I also have a rubber black box that fits between the ignition pickups with two other wires coming out and cannot find where they go too :roll:
#2 PostAuthor: ADRIAN H » Sun Nov 09, 2014 6:51 pm
I have sent you Kawasaki service manual KZ1000, KZ1100 with GPZ1100B1 Suppliment) to your email, via a Dropsend link. As the File is 48mb.
Hope this helps.
sockpuppet
#3 PostAuthor: sockpuppet » Sun Nov 09, 2014 6:51 pm
Has the sidestand switch got 2 wires , or 4 ?
Just wondering if its the same as a B2 .
Both my B2`s have 4 wires -- Bullet connectors one pink male one and 3
female- -
even though the wiring diagram in my manual shows just a green and
brown!!
3 of them -- (pink and 2 black) plug into a small sub harness about 3" long
with a block type connector on , which plugs into a block connector that
comes out of the harness under the tank , the remaining one plugs into a
bullet connector alongside .
Regards
Mick
big green bus
#4 PostAuthor: big green bus » Sun Nov 09, 2014 7:47 pm
sounds about right but I cannot find any wires on the B1 loom :roll:
sockpuppet
#5 PostAuthor: sockpuppet » Sun Nov 09, 2014 8:08 pm
On mine 3 wires ( Red ,brown & green)come out of harness to a white 3 pin block connector right above the carb inlet rubbers.
doebag
#6 PostAuthor: doebag » Sun Nov 09, 2014 8:14 pm
Steve
What is the history of your bike/wiring loom/sidestand ?
Do you mean the extra cut out switch on the left hand switch gear ?
If so, these were only fitted to UK and German market bikes.
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
big green bus
#7 PostAuthor: big green bus » Sun Nov 09, 2014 8:52 pm
It is a UK bike I am trying to fit the clutch lockout and side stand cut back to original spec
doebag
#8 PostAuthor: doebag » Mon Nov 10, 2014 3:41 pm
This may help [ or not !]
My 1100 shaft has a four wire harness from the side stand switch.
1 pink, 1 blue/white and 2 black
All end in separate bullet connectors, joining identical colour wires in the main harness under the fuel tank by the left hand top tube.
UK model with a cut out switch on the l/h switchgear.
Outlaw Josey Wales
Member No. 555
big green bus
#9 PostAuthor: big green bus » Mon Nov 10, 2014 9:31 pm
doebag wrote:This may help [ or not !]
yes those are the ones I must have the wrong L/H switch
big green bus
#10 PostAuthor: big green bus » Wed Nov 12, 2014 5:58 pm
#11 PostAuthor: Pigford » Wed Nov 12, 2014 6:09 pm
Out of focus :?:
big green bus
#12 PostAuthor: big green bus » Wed Nov 12, 2014 6:18 pm
rubber block (nothing on it) the plugs match the colours of the ignition pickups and can be plugged in to the line god knows where the other two wires go :roll:
sockpuppet
#13 PostAuthor: sockpuppet » Wed Nov 12, 2014 9:48 pm
Are you having injection or carbs ?
If you`re using carbs this bit can be left out and the pickup plug and igniter plug fitted directly together .
( I have one of these in the box of bits i have from when i converted mine 20 odd years ago so i`m guessing the 2 wires go to something to do with the injection system that needs a feed from the ignition circuit !)
Regards Mick
big green bus
#14 PostAuthor: big green bus » Thu Nov 13, 2014 3:52 pm
putting the injection back on, putting it back to standard as much as possible
steve.w
#15 PostAuthor: steve.w » Thu Nov 13, 2014 3:55 pm
ill show ya were the wires go when i come down !!! have ya snips ready :twisted:
