Oil cooler
Pinhead
Oil cooler
#1 PostAuthor: Pinhead » Mon Sep 08, 2014 8:37 pm
Hi
I have a small oil cooler on my z900 a4
i was thing of taking it off as I'm doing a rebuild but just thought I would ask,
As this is my first z900 do they run that hot as to need one
Pin
z1000puddin
#2 PostAuthor: z1000puddin » Mon Sep 08, 2014 8:45 pm
Pin,
Unless you are ragging it around a track - Or in California - No need for a oil cooler.
They came out of the factory without them.
I took mine off a few years ago.
Stu
Zed til Dead
#3 PostAuthor: chrisu » Mon Sep 08, 2014 10:10 pm
Std 900 no need
Big bore yes I think you do.
Pinhead
#4 PostAuthor: Pinhead » Fri Sep 12, 2014 7:38 pm
Hi
I have taken the oil cooler off
What do you need to do to the two oil feeds from the engine
Can you just buy blanking bolts
Pin
:shock:
#5 PostAuthor: chrisu » Fri Sep 12, 2014 8:03 pm
no....
there is the original part which links the two outlets and houses the oil pressure switch. you can't just blank them off.
i'd assume john browse or someone similar has one................
or maybe someone on the site has a spare.
Pinhead
#6 PostAuthor: Pinhead » Fri Sep 12, 2014 8:31 pm
Hi
Is the oil bypass valve the same for all z900
#7 PostAuthor: Pigford » Fri Sep 12, 2014 9:03 pm
Yes - all kickstart motors 900 & 1000 :wink:
#8 PostAuthor: zed1015 » Sat Sep 13, 2014 6:27 am
Pinhead wrote:Hi
If you are referring to the part you need to replace the oil cooler take offs then it is the OIL PRESSURE SWITCH HOUSING you need .
The bypass valve is a different item and is located inside the engine .
Either way both these parts from other z9/1000 kickstart equipped engines are common throughout the range.
tlc
International Rep
#9 PostAuthor: tlc » Sat Sep 13, 2014 6:50 am
I have the part you need spare.
Let me know if you want it.
Asphalt Cowboy
Pinhead
#10 PostAuthor: Pinhead » Sun Sep 14, 2014 7:45 am
Hi all
Thanks for all your help
I found one on Ebay I think it's the right one
If not I will get back to you
Pin
Padders
#11 PostAuthor: Padders » Sun Sep 14, 2014 7:58 am
Hi I am looking for some oil cooler take offs if you are selling the ones you are taking off the engine.
Cheers Ian
PUM 13
Pinhead
#12 PostAuthor: Pinhead » Mon Sep 15, 2014 8:52 pm
Hi
I'm going to keep the take offs as on the back burner
I might build a 1280 big bore
Pin
