Hi
I have a small oil cooler on my z900 a4
i was thing of taking it off as I'm doing a rebuild but just thought I would ask,
As this is my first z900 do they run that hot as to need one
Pin
Oil cooler
- z1000puddin
Pinhead wrote:Hi
Is the oil bypass valve the same for all z900
If you are referring to the part you need to replace the oil cooler take offs then it is the OIL PRESSURE SWITCH HOUSING you need .
The bypass valve is a different item and is located inside the engine .
Either way both these parts from other z9/1000 kickstart equipped engines are common throughout the range.
