just a question on the valve springs on my z1a. the inner springs on all of my springs are tight inside the bigger ones is this normal on these heads.on all the other heads i have stripped in the past the inner springs are loose.also in the book it says free length should be 39.3 mine are 41.3.when i stripped it the engine looked like its not run for years and some valves are bent could this have caused it.
cheers
valve springs z1
http://www.saisei-europe.com/Shop/c/eng ... /valve-set
http://www.saisei-europe.com/Shop/c/eng ... ve-springs
Oversize guides available to order.
